VAF on Twitter:
@VansAirForceNet
  #11
Old 08-07-2017, 08:53 PM
AviatorJ AviatorJ is offline
Originally Posted by Bill Boyd View Post
But if you're cutting for the McMaster seals, you will ultimately grind/sand for a 1/4" gap from the door, and that takes the curved portion of the door sill pretty much flat, parallel to the inside surface of the door. This results in a sharp edge, and necessitates building up the door sill edge to a consistent 1/4" thickness. Best done IMO as others have done, with pieces of McMaster seal used as a removable/reusable mold to hold flox in place on the door sill while it cures. Gives a perfect fit. Do other stuff while it cures. The leftover piece from a 25 foot order will do one doorway in about 5 cure sessions/nights. But be careful with it. Tears if handled roughly.
I had issues with that approach. Ended up having to manually build everything up later and then sand it all down. Ended up turning out great but my initial cutting to the scribe line probably made the entire thing much harder.
Justin
RV-10, N10JW
Flying since 2/14/2019
http://operationrv10.blogspot.com/
Old 08-07-2017, 09:04 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default McMaster Carr door seal
Originally Posted by jeffwhip View Post
How can I find Ivan K's measurements? I'm getting ready to fit my cabin cover this week!
Here is a link to the section of my build for the doors which includes a number of pictures showing measurements of where to cut. The very first slide is actually a little video, which I had forgotten all about, it gives some specific measurements. Some areas get a bit thin but that is required in order to be able to close the door using the McMaster Carr seal. I built up the inside of those areas so that the seal grip was retained.
https://ivankristensen.smugmug.com/B...t/Cabin-doors/
Ivan
Ivan Kristensen
RV-10 (C-GMDV) 1500hrs. TT FOR SALE!
Dual GRT 8.4" HXr EFIS, VP-200, TT A/P, Avidyne IFD440, uAvionixX ADS-B out, Sky Radar WX and Traffic, Dual EI's (one Lightspeed & one SDS CPI)
RV-14A Now flying. 110hrs TT
SDS EFI/EI FADEC system
An ADVANCED PANEL from AFS. Dual AF5600 10.4" EFIS'
Avidyne IFD540 FMS Navigator,
uAvionix AV-30 B/U EFIS + TBX
Lycoming Thunderbolt IO-390 EXP 119
Check out my FB page.
https://www.facebook.com/groups/976335912852865
Old 08-08-2017, 06:36 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
What I describe is one approach to "building it up later." In my case, sanding the cabin top to a distance of 1/4" away from the inside of the doors was beyond any scribe lines I could make out.
He will have to sand some doorway material away just to get clearance for the door pieces to seat flush for initial assembly (drilling and clecoing to the outside of the cabin while the door bond cures). From there it's very straightforward to scribe the 1/4" gap line from the inner door face, and check progress as he goes with a go/no-go feeler gauge.
In my case, much of the doorway was left with a knife-edge after this final trim. What was still full thickness was checked with a 1/4" gap gauge and if necessary ground down to 1/4" thickness for the edge seal to grip to. The rest was built up with flox, cast-in-place with seal material as the female mold. I'm very happy with the results so far.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 80 hours
66 years running stock DNA
Old 08-08-2017, 09:41 AM
Lynnb's Avatar
Lynnb Lynnb is offline
Thanks for all the reply's. Lynn
RV-10
First Flight 12-17-2020
