Old 05-16-2017, 08:29 AM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
Default TT Gemini question
I am planning a long flight tomorrow and hope to be able to use the newly installed A/P. Last time at the hangar, I had worked out the last of the gremlins and the A/P seemed to be behaving in a logical fashion, with one exception. I could not get it to fly a direct-to, or a flight plan, entered into my GRT Sport EFIS. The A/P seems to be following some green course line instead, and I cannot identify the source of this line.
I do recall reading a reference to a green course line of sorts in one of the owner's manuals for the A/P or the EFIS, but I haven't been able to find it since. When I have tried to follow a direct-to or flight plan, I have been in ENAV in the EFIS. So I would think that even if the green line is a selected heading line of some sort, it would be missing from the map display while I was in ENAV instead HDG mode in the EFIS.
Does anyone have any ideas for what might be happening? I presumed I could try to figure it out next time in the plane but I'd rather have some knowledge of the situation before I get to the hangar tomorrow morning.
Thanks!!
Old 05-16-2017, 11:53 AM
lr172 lr172 is offline
On my HXr, the flight plan course line is white and the green line originating in the center of the rose/plane icon is slaved to the heading bug. Sounds like your TT is following the heading and not the course. You can confirm this by resetting the heading bug and see if the TT follows it. I use the GRT AP, so don't know much about the config for external AP's. I would speculate that your config is wrong and when in enav mode, the course data is going somewhere other than the TT or not going at all. I would bet that the GRT provides heading and track data at all times on the interface ports and the TT is using that heading as a default when activated, as it is not getting any other course data to follow. I would call GRT and go through your configuration settings.
Larry
Old 05-16-2017, 12:50 PM
AndyRV7's Avatar
That sounds just about exactly correct Larry. Thanks.
Old 05-16-2017, 02:03 PM
AndyRV7's Avatar
GRT says the A/P control unit has to be in NAV mode for the EFIS to tell it what course to fly. Otherwise it ignores the course and will fly heading instead.
Old 05-16-2017, 02:31 PM
BobTurner BobTurner is online now
Just to be clear for those who don't read thread titles, this is true for TT autopilots, but is not true for Trio Pro autopilots...
Old 05-16-2017, 02:42 PM
jeffkersey's Avatar
jeffkersey jeffkersey is offline
Default GPSS mode
I have a TT Gemini AP. I do not have an efis that is will communicate with. I do know that the auto-pilot must be in GPSS mode (toggle left to enter GPSS mode) to fly a flight plan.
Jeff Kersey
RV7A Purchased Flying
Dues paid
Old 05-16-2017, 02:52 PM
AndyRV7's Avatar
I felt like I came so far but I still feel like a noob. Yes, apparently, you have to use the GPSS mode to allow the EFIS to control the A/P. Such a simple fix.
Old 05-16-2017, 05:12 PM
jeffkersey's Avatar
Default Glad you got it working....
Glad that it was an easy fix. I have been happy with the way the autopilot flys but the negative about this unit is the interface. In turbulence, it is easy to make unwanted input changes. You will probably not have those issues as you have dedicated knobs and buttons on the efis.
Tailwinds and Blue Skys...
Jeff
Jeff Kersey
Dues paid
Old 05-16-2017, 05:40 PM
AndyRV7's Avatar
Jeff
Someone suggested to me to kind of pinch the toggle between two fingers and use my thumb to push it. I've gotten better at that. Pushing the toggle in was really the only input that was difficult. Give it a try. It helps a lot to stabilize the toggle with your fingers. But I know what you mean. Tomorrow will be my 1st successful flight using the EFIS as a control (should be anyway...). I am excited to see how that goes. I never minded just using the A/P unit itself.
Old 05-16-2017, 08:01 PM
jeffkersey's Avatar
Default Copy
I have been using that method already. Sometimes in turbulence I accidentally toggle while I am rotating the knob. Also, it is sometimes hard to do fine tune heading adjustment (1 degree at a time). You have to push in and rotate at the same time.... It fly's fairly smooth when it is engaged and it has made single pilot IFR much easier...
Jeff Kersey
Dues paid
