Old 02-25-2017, 10:55 PM
petehowell's Avatar
Default $10 Microbrew Valve-o-scope (Borescope)
Is it awesome, no. Does it do the job, yes. Is it the price of a micro-brew, yes. The $10 valve-o-scope. It works for me - YMMV. Well worth the 10bux.
Here is my setup: Cheapo $9.12 borescope(waterproof!!) The scope is taped to a length of 14ga copper wire to get the required hook.
An old laptop running Linux Mint 18 with the "Cheese" webcam program displays the video and can snap pics. Linux Mint is a cool, free OS. A phone or tablet would work, too.
Like I said - the pics are not museum quality, but they let you see valves just fine - did I mention less than $10??
Cyl 1
Cyl 2
Cyl 3
Cyl 4
Pete
Amateur Plane - RV-9A N789PH - 2450+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 02-25-2017, 11:09 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Too cool Pete - I was looking at the nice Oregon Scientific articulating scope today at the Puyallup show, and as nice as they are, it's hard to pass one of these up for that price! Got one on the way for myself.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-26-2017, 06:26 AM
DanH's Avatar
DanH DanH is offline
There are a bunch of them on Tomtop.com also....
http://www.tomtop.com/endoscopes-206/p-e0430.html
http://www.tomtop.com/endoscopes-206/p-e1491r.html
http://www.tomtop.com/endoscopes-206/p-h13922.html
http://www.tomtop.com/endoscopes-206/p-e1489b.html
http://www.tomtop.com/endoscopes-206/p-e0967-1.html
...and dozens more. This one struck me as interesting, just because of the headline, 300,000 pixels:
http://www.tomtop.com/endoscopes-206/p-h8272.html
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-26-2017, 07:03 AM
Nothing for Mac?
Old 02-26-2017, 07:37 AM
plehrke's Avatar
plehrke plehrke is offline
Nothing for Mac?
Just got this one last week on amazon. a little more then $10. got it because of the IOS interface and the semi-ridged wire. Used it this week during my conditional inspection. Worked great to look at and photograph inside wing and tail structure, not so good for engine stuff. The 90 deg mirror accessory to look at the values not very good, just got a lot of cylinder walls. Also focal length of 1-2" seems a bit long so blurry when get too close.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 02-26-2017, 08:32 AM
petehowell's Avatar
Default 10mm Camera
Good find, Dan!
10mm head should have a better camera, but will make it tight to fold it over and get it in the plug hole.
Someone might need to part with a brew and a half to give it a look see!
Pete
St. Paul, MN
Old 02-26-2017, 10:21 AM
az_gila's Avatar
az_gila az_gila is offline
Question Focusing
The key for our cylinder use would seem to be the focal length.
The one in the OP states 1.6 inches min.
For the list from DanH, in order -
2.4 inch min - no spec - 1.6 to 2.4 inches - no spec - 2.4 inch min.
Anyone find a version stating less than 4cm/1.6in?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-26-2017, 12:32 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default Options
Haven't tried it, but here is a IOS cam for 3-10cm at $14
Moderator's note: Hey Chuck, you cut and pasted text into your URL field, so the link returns a big dead end error. Please supply a valid URL. Thanks, Don H.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 02-26-2017, 07:44 PM
gerrychuck gerrychuck is offline
Nothing for Mac?
Most of these little fellas will work fine with a Mac, Vlad; you just open PhotoBooth or FaceTime and select the camera as the video source. I'm planning to buy one myself, and intend to use it with a MacBook Pro and and Android tablet. There are DOZENS of these things listed on both eBay and Amazon.
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
