Old 01-29-2017, 07:36 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default Fuel Pump
Hi all
Yesterday I took off Carson City heading for Sacramento to see my friends.
As I leveled off at 10,500 feet I did a instrument scan in the fuel pressure was reading .6 pounds and blinking red at me , after a few moments it was reading zero .The engine was running smooth for a little bit then things got rough I turned on the boost pump and headed back to Carson. What a shame the air was smooth the snowfall on the Sierras was absolutely beautiful I could've continued on my boost pump but I thought better of that plan. I just thought I would share the experience. My new pump will be here on Tuesday and all will be better again.
Dayton Murdock
VAF#408 RV4 N359DM O360 C/S, Dual P_Mags, AFS Efis, Trutrak A/P, Leather, Electric trim and flaps, Led lights, Freeflight ADSB and it is painted Red, Flying 1105 hrs 11/28/20
Builder Log
Old 01-29-2017, 07:54 AM
flynwest flynwest is offline
Default fuel pump
Good on ya break the accident chain at the first link.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
RV 8 Fast back built and sold
RV 10 Building
Dues paid 2022
Dan "Nordo" West
Old 01-29-2017, 09:10 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default more info please
Dayton,
Good Job.
Can you give us more info on age and TT on fuel pump?
Mine is 20yrs old and 1100+ hours since new and wondering if I should replace mine as preventative maintenance. To preclude what you just experienced.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 01-29-2017, 10:13 AM
My fuel pump was new with the engine rebuild. it has 886 hours on it
Dayton Murdock
Builder Log
Old 01-29-2017, 10:18 AM
climberrn's Avatar
climberrn climberrn is offline
I did an autopsy on mine that failed last summer. The main diaphragm was intact, but there are 2 nickel sized rubber diaphragms that act as check valves. Mine were hardened and not sealing very well.
Glad your trip back was a non issue.
Joel
N626JA
RV-7A at CXP
Flying!
Old 01-29-2017, 11:53 AM
Chkaharyer99 Chkaharyer99 is offline
Originally Posted by Dayton Murdock View Post
Hi all
Thanks for the post. Great decision. Learning/reinforcing knowledge vicariously is good.
Last week, while doing my run up my TYCO electric fuel pump toggle breaker failed. That was a no go.
Not many good options at 10.5 over the snowy Sierra's. I'm glad you're safe!
Charlie
RV-8
Old 01-29-2017, 12:16 PM
Leland's Avatar
Leland Leland is offline
Default Weak Fuel Pump
With 850 hours since new on a new Vans O320, I noticed my fuel pressure was reading about 0.6 psi, on climb out, after shutting the electric pump off. Since the fuel pressure came up to about 5 psi with the electric pump on, I assumed that the problem was with the mechanical pump. Replacing the mechanical pump was not difficult except for safety wiring the new pump.
Leland
RV-9A with 890 hours and 11 years of flying
Old 01-29-2017, 02:22 PM
cajunwings cajunwings is offline
Default Rubber Parts
I have done a fair amount of aviation maintenance consulting and pre-buys over they years and always tell clients that after 10 years a rubber part has lived its life & doesn't owe you anything. That's every seal, o-ring, hose, diaphragm, tire, tube ect on the plane. Engine driven fuel pumps are one of those parts that maybe should be replaced at 10 years to keep trouble to a minimum.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 01-30-2017, 06:18 AM
Larry DeCamp Larry DeCamp is offline
Default Fuel Pressure Variation ?
My low pressure pump was installed maybe 5 years ago ( previous owner ) and has about 120 hours on it. The pressure goes low sometimes and back to normal, about 2-3 psi fluctuation. Boost pump always raises the pressure to normal. What causes fluctuation in the mechanical pump?
Also, if I climb to 8,500 MSL, pressure drops to bottom of green and returns to normal at 500 MSL (airport) for either pump. The OP goes down 5 psi also . Reducing atmospheric pressure should increase the gauge reading assuming the fluid pressures are controlled by springs in the fuel pump and OP relief valve. What am I missing ?
Larry DeCamp
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 01-30-2017, 06:41 AM
rv8guy's Avatar
rv8guy rv8guy is offline
Good job Dayton. Keep em flying
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
