Old 10-27-2016, 09:08 PM
petehowell's Avatar
Default 1700 Hours
Just completed the 1700 hr oil change with compression check and borescope pics of the exhaust valves. - Thanks to Alex P for letting me try out his new scope!
Oil filter media and screen were examined and were clean
Compression check with cold cylinders
Cylinder 1 79/80
Cylinder 2 76/80
Cylinder 3 78/80
Cylinder 4 78/80
I run 80-90% mogas and almost always LOP. The #1 Exahaust valve was replaced 100hrs ago.
This unit leaks a lot of hot air......
Pete
Amateur Plane - RV-9A N789PH - 2450+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 10-27-2016, 09:33 PM
erich weaver's Avatar
Wow, those look clean as a whistle.
Suggestion to moderators:
A decent borescope is now very affordable and many of us have one now. What do you think of starting a sticky: "Show Me Your Exhaust Valves" so we can accumulate a good mass of these pictures in one place and compare our own to everyone else's just like we do for instrument panels etc. Good idea?
Erich
Old 10-28-2016, 05:39 AM
Weasel's Avatar
Weasel Weasel is offline
Nice Pete. 1700hrs of good times
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1700hr counting
RV-10 N7631T 820hr Sold
RV-8 700+hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 10-30-2016, 09:01 PM
Darin Watson Darin Watson is offline
Nice photos, what are the details of your scope?
Regards,
Darin
C-GULF RV-7 located in Calgary, AB
Old 10-31-2016, 07:38 AM
AlexPeterson's Avatar
Vividia Ablescope VA-400 USB Rigid Borescope Endoscope with 180 Degree Articulating 8.5mm Diameter Probe
Pete took all my fun away of being the first to use it for scoping valves... I learned of this scope from a thread on VAF a while back, don't recall whom to credit though...
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 10-31-2016, 12:23 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Default 1700 hrs
Very impressive! I generally limit my oil changes to 30-40 hrs.
Seriously, those are some clean valves!! The ones with pics that link properly.
Bryan
Houston
Old 10-31-2016, 08:20 PM
Pete, the story to me is you have 1700 hours. Thats great. What a fun 1700!
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 10-31-2016, 08:52 PM
Congrats Pete. You are doing something right.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
