Go Back   VAF Forums > Model Specific > RV-14
Old 07-06-2016, 07:36 PM
RumbaChad's Avatar
RumbaChad RumbaChad is offline
Default RV-14 Common Fuselage Wiring Harness
Van's has released the WH-00125 Common Fuselage Wiring Harness for the RV-14.
The drawings for this harness are also available on the Van's Aircraft Downloads Website in DWG form. These may be used as an electrical systems overview for the standard wiring harnesses installed in the RV-14 wing and tailcone.
The harness itself provides a bridge between the wing and fuselage wiring harnesses, and is designed to provide a good starting point towards interfacing with AFS, Dynon or Garmin EFIS systems, with enough wire to reach behind the RV-14 sub-panel.
Please see the updated RV-14 Avionics Letter for more information.
Adam Burch,
Any opinions expressed in this message are my own and not those of my employer.
Old 07-06-2016, 09:15 PM
n982sx n982sx is offline
Hooray, I got my WH-00125 from Stein yesterday without any drawings. They said I would have to wait for Van's to release it.
It will be nice to have the documentation. It's quite a harness.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 07-07-2016, 07:51 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Amazing the detail available with the -14! Things have come a long way!
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 07-08-2016, 10:25 AM
RumbaChad's Avatar
Default Common Fuselage Harness Installation Instructions
Additionally, RV-14 Section 55: Common Fuselage Harness has been posted describing the installation of the WH-00125 Harness.
LINK
Adam Burch,
