Old 06-16-2016, 10:54 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Question Autopilot research
Way way back in early aughts, as a pure research project, I built an RC servo wing-leveler for my RV-3. It used a small trim tab. The solid state gyros then where very primitive with poor accuracy. It had a bad habit of drifting quickly and ultimately, it was a failure.
Wow have things changed. You can buy a $10 12-dof controller for multi-copters which should clearly keep an aircraft perfectly level. Each axis has separately configurable feedback coefficients which can be set for the mass / roll inertia of a full-scale.
Has anyone experimented with using RC Quad Copter controllers as auto pilot?
Thanks!
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 06-16-2016, 11:30 AM
CATPart CATPart is offline
This has been on my mind for quite a while. It would work fine in my opinion, like the eco. I actually took my homebuilt quad flying in the back of my -4 with it connected to my nexus thru Bluetooth, to experiment, to see if the horizon would keep level. Seemed to work pretty well. My experiment ended there, with plans to at the very least, have a cheap artificial horizon.
Old 06-16-2016, 11:51 AM
BruceMe's Avatar
I made a post to my blog on what I had in mind. If you find it interesting, let me know.
http://SportVFR.blogspot.com
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 08-10-2017, 12:16 AM
BruceMe's Avatar
So I've been busy on other projects, like repairing an RV-6 and purposely let my electronics projects drop off.
Since I made this, I've had boards made to support this.
https://goo.gl/photos/sR6a7jmjDBA5bC7U6
It's quite basic, and I haven't tried flight yet. I recall when I set this aside, I had it mostly working on the bench, but it need further refinement and flight testing/debugging.
The core of it is up to 8 channels of analog input with handy through holes for pull-up/down resistors to match the most resistance sensor (OilT, OilP,CHT,EGT,OAT,MP...). For more complicated sensors that require special component, I have two I2C inputs. There are lots of really cheap I2C modules for pressure, inertia/gyros and magnetic compass. Basically you can build your own air/engine data collector.
Let me know what you think. I have a few extra boards I'd send to anyone who's serious.
Here's the GitHub repo on the very basic LCD display version of this.
https://github.com/bruceme/SportVFR
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 08-10-2017, 06:37 AM
rv7charlie rv7charlie is offline
It's quite tempting to request a board, but I can't claim to be serious at the moment. Once the Twinstar restoration is complete, and the RV-7 flies, you may hear from me again.
Thanks for the links, and if you decide to dive back into the project, please keep us updated.
Charlie
