Old 05-23-2016, 10:17 AM
p51dplt p51dplt is offline
Default Dynon Servo wiring question
Can someone help shed some light on why the servo wiring schematic shows two female D-Sub connectors? I'm not following why or what there would be two for.
Thanks.
Brant Seghetti
Top Cover Aviation
Nut Tree, CA
P-51, RV-8, 90A, S1
ATP, A&P, IA
Dues Gladly Paid
Old 05-23-2016, 12:34 PM
krw5927 krw5927 is offline
Unsure what schematic you're looking at. Got a photo or a link?
Kurt W.
RV9A
FLYING!!!
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Brant,
We have a lot of wiring diagrams. Where are you seeing this?
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 05-23-2016, 12:39 PM
Ron B. Ron B. is offline
Right at the servo you put a female connector and male connector to make a line disconnect before the harness for when you need to remove the servo you just disconnect the Sub Ds and leave the harness, if that is what you are referring to.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 05-23-2016, 12:51 PM
Raymo's Avatar
Raymo Raymo is offline
The harness itself has two female connectors. Each end connects to a male DB9. One on the servo, one to the network hub/EFIS.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 05-23-2016, 04:36 PM
Originally Posted by dynonsupport View Post
Brant,
Figure 100 on page 10-10 of the SV installation manual.
Brant Seghetti
Top Cover Aviation
Nut Tree, CA
P-51, RV-8, 90A, S1
ATP, A&P, IA
Dues Gladly Paid
Old 05-23-2016, 05:10 PM
Brant,
The connector at the servo end is there just so you can maintain the servo in case you ever need to remove it. If you want to direct connect the wires you can.
Dynon Avionics
425-402-0433
