Old 05-16-2016, 08:25 PM
Jesse's Avatar
Jesse Jesse is offline
Default Scary problem accidentally found!
I had a guy fly up to visit my shop on Saturday. I had talked to him once or twice about how difficult it has been to start his O-360. He was able to get it started on Saturday morning to come visit me (hoping I would be here, which I happened to be). Then he couldn't get it started again to get home, which very possibly saved his life, and very likely saved his plane.
The starting problem appears to be a bad Mag, or at least bad points. We popped in a Slick 4372 that we had on the shelf in place of his 4373 after talking to the Slick guru about he compatibility and how to time it for testing. We out the mag in and it started on the second blade. We ran the engine for about 15-20 seconds. After I shut down my assistants noticed that the firewall was covered with oil. Upon closer examination, this is what we found.
Which easily became this with almost no force.
In this view you can see the oil on the firewall.
Someone had used an aluminum line with flares to extend the flexible oil pressure line to the sensor. Due to the vibration, the flare had broken and the line started to leak. With the tiny amount of force it took to pull the line out of the flare nut, I am confident that a couple more seconds of engine run with 75 psi of oil pressure would have forced the line out and would have started pumping oil overboard. I don't know how long it would have taken to empty 6 quarts of oil at that pressure and that size line, but I am guessing about the time it would take to taxi and takeoff and get to maybe a couple of hundred feet. Then a seized engine or worse and into the trees. That's scary to me! The owner (who will remain unnamed, if he is on here, it's for the benefit of others) mentioned, after I sent him a picture and a short version of the above scenario, that he had seen the line when he replaced the battery after he ran the first one dead trying to start, and it looked a little weird.
Please, fellow VAFers, if something looks weird, please have someone else (preferably an aircraft mechanic) look at it to see if it is normal or an accident waiting to happen. This brigs to mind Vic's post recently of an oil suction screen packed full of crud. That got my attention. Hopefully this will get someone else's attention who may have aluminum rigid lines firewall forward in a critical engine function.
Jesse Saint
Old 05-16-2016, 09:31 PM
digidocs's Avatar
digidocs digidocs is offline
Nice job, Jesse. Close one for sure!
I've always wondered why we don't see more oil level indication/warning systems. It seems like they would be very useful in cases like this.
David
Old 05-16-2016, 09:43 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default 👌👍👍👍👍👍👍
Great job Jesse!
You're attention and your assistant's attention to detail is inmeasurable in this case!
Don
Old 05-16-2016, 09:45 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is online now
Whoa! THAT'S frightening.
Did the line at least have a restrictor fitting on the engine-to-flex-line?
Old 05-16-2016, 09:54 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
And no unsupported T-fittings hanging in mid-space....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-16-2016, 10:04 PM
coffeeguy coffeeguy is offline
Default battery replacement
Is is just an illusion or is it impossible to pull the battery out to replace it with the oil line routed over the top?
Jeff Dingbaum
RV-14A empennage, wings, fuselage, finish
Cherokee 180
Old 05-16-2016, 10:34 PM
F1R F1R is offline
FWIW the battery hold down strap looks like a potential accident in waiting.
Old 05-16-2016, 10:48 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
It just looks like he put heat shrink over the hold down bar. Actually seems like a pretty good idea to prevent accidental shorts while doing maintenance or charging with alligator clamps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2022
Old 05-16-2016, 11:02 PM
Jrskygod Jrskygod is offline
Somebody trying to save a buck used a hose they had lying around that was too short so they went to the used fitting bucket and cobbled together an extension. See this kinda stuff on experimental all the time. Accident looking for a happening. Sure am glad someone caught it before the inevitable accident.
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 05-17-2016, 05:46 AM
bret's Avatar
bret bret is offline
Thanks for sharing, it is brave for anyone to share stuff like this to everyone, for the benefit of all, Thanks! I too am looking at the battery hold down and it looks like only a couple of mills of heat shrink stopping a direct short across the battery, I think that hold down needs a visit to the band saw for reshaping to clear the battery posts!
