Old 05-07-2016, 05:29 PM
Bernie RV7 Bernie RV7 is offline
Default New SB issued 6 May 2016 (SB16-03-28)
Cracking of wing aft spar web at the inboard aileron hinge bracket attach rivets
http://www.vansaircraft.com/pdf/sb16-03-28.pdf
Bernie Flying RV6
Melbourne Australia
Old 05-07-2016, 05:50 PM
tgmillso tgmillso is offline
Default Thanks
Really appreciate you posting this, as I'm just days away from riveting on my aileron hinge brackets. I'm sure there are others out there in a similar situation.
Tom.
Old 05-07-2016, 06:25 PM
Dean Pichon Dean Pichon is offline
What a disappointing development. Does anyone know how many reports of this type of cracking Van's received prior to issuing the SB?
It sure would be nice if Doug set some sort of database where people could report and share their findings as they execute the inspection portion of this SB. The data should be available fairly quickly given the direction to inspect before further flight.
Old 05-07-2016, 07:33 PM
Steve Melton's Avatar
It would be nice to receive an "inspect before further flight" by an email notice. Not that I'm asking for more SB's.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 05-07-2016, 07:47 PM
Aggie78 Aggie78 is offline
Default Concur!
Steve,
I agree.
On another note, I posted up a message over on the General Discussion forum to drive folks over here.
I was just killing time on a Saturday night and rarely check this part of VAF. Would have been weeks before I'd seen it otherwise.
Pretty important SB to be buried off the main storefront, so I gave a heads-up.
Rob
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
Old 05-07-2016, 08:31 PM
Default $$$
Is this a first for Vans? SB notes that there is a charge if you need parts.
Old 05-07-2016, 08:49 PM
RV-4 RV-4 is offline
Thumbs up SB 16-03-28
Thank you Bernie for posting this, it is really appreciated...
''SB notes that there is a charge if you need parts. '' Amazing that we have to pay for parts to fix a design problems...
Bruno
Old 05-07-2016, 08:51 PM
wirejock's Avatar
wirejock wirejock is offline
Default Welcome
Nope. Welcome to the club. Good news, the SB kits are usually inexpensive. It's the errors installing them that cost.
BTW, anyone notice the rivet on the bracket in the SB are installed backwards. I suspect most are done per Mil-Spec and installed with the factory side on the forward side of the aft spar. Drilling the shop side will be a bit more tricky.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 05-07-2016, 10:52 PM
PCHunt PCHunt is offline
Quote from SB: It is unlikely that RV-6/6A wings will be affected. If cracks are present in RV-6/6A aircraft, email Van’s Engineering Dept for instructions, with photos of the cracks, for a specific repair scheme.
Curiosity question. What is different about the -6/6A wing that makes it unlikely that cracks would occur?
I'm a non-builder.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2021 Donation+, Gladly Sent
Old 05-07-2016, 11:00 PM
Originally Posted by PCHunt View Post
Quote from SB: It is unlikely that RV-6/6A wings will be affected. If cracks are present in RV-6/6A aircraft, email Van?s Engineering Dept for instructions, with photos of the cracks, for a specific repair scheme.
I'm a non-builder.
Another non-builder question....
What's causing the cracks that are being seen?
Assembly error? Fatigue? Something else?
Which wings are they happening on? QB? SB? Both?
Rob Schroer
RV-7/N75WV
YIO-360-M1B
