Old 03-31-2016, 08:54 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Default Introducing the Advanced AF-5700 12.1" Display
From Dynon?s Advanced Flight Systems division, the new AF-5700 display - featuring a new ADVANCED Touch interface - is the smallest form factor 12? EFIS available.
The new AF-5700 display combines the largest-in-class 12.1? screen with a minimized installation footprint. With its new ADVANCED Touch interface, the AF-5700 gives pilots the opportunity to install a large screen EFIS in an instrument panel that previously could not support one.
The AF-5700?s sleek form factor was designed to maximize space utilization, provide the largest amount of functional screen area possible, and minimize the panel space required. The large 12.1? screen allows for a larger display of information, more effective split-screen multi-tasking, and reduced information clutter.
The new ADVANCED Touch interface adds many options for data entry through touch keys and gestures, emphasizing the same philosophy of shallow menu structure found on all AF-5000 displays. The AF-5700 display is priced at $4800.
AF-5700 displays are expected to start shipping in April 2016.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 03-31-2016, 09:37 PM
Gash's Avatar
Gash Gash is offline
Beautiful panel! Way to go Dynon!
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A
Yak 50 Red Thunder Airshows
=VAF= donor 2021
Old 04-01-2016, 12:27 PM
N402RH's Avatar
N402RH N402RH is offline
More pictures of the panel from last nights test flight:
http://www.vansairforce.com/communit...94#post1067294
Rob Hickman
Advanced Flight Systems Inc.
Old 04-01-2016, 06:06 PM
kamikaze kamikaze is offline
That is one gigantic screen, beautiful! Will it fit in a 7/9 panel in some way?
Edit: Fired up the DXF viewer, looks like it's a tight fit, but might be possible (Not taking into account the structures behind the panel that is). Definitely doable with a slightly extended panel ...
J.F.
Sling 4 empennage kit on order!
Future EAA 245 Member (Hopefully)
Current Piper Warrior PA-28-151 Owner/Pilot
Ottawa, Ontario, Canada
http://www.sling4.ninja
Old 04-02-2016, 12:33 PM
N402RH's Avatar
Default AF-5700 Dimensions
The AF-5700 will easily fit in a RV-7/9 panel.
Model------Width-------Height
5800-------11.50"-------9.00"
5700-------10.85"-------8.90"
5600-------10.25"-------8.15"
5500-------9.125"-------7.125"
Rob Hickman
N402RH RV-10
Old 04-04-2016, 09:26 AM
douglassmt douglassmt is offline
Default Panel frame
Is that Geoff's standard symmetrical panel? If so, I might be talked into the big screen in the middle if I don't have to change the panel frame.
Bryan Douglass
=VAF= 2022 dues paid
RV-10 N242BD
Old 04-04-2016, 09:45 AM
Zac@AerosportProducts Zac@AerosportProducts is offline
That is the newer 310 Symmetrical Panel from Aerosport..
http://aerosportproducts.com/310panel.htm
Zac Holcomb
Future builder of something, someday.
I live it through all of you. Thanks!
Zac@AerosportProducts.com
3DPrint@AerosportModeling.com
Old 04-08-2016, 09:31 AM
GigAir GigAir is offline
Rob,
I know you have just begun testing, but down the road, will you incorporate two AFS 5700, as an option, on a RV-14 "Quick Panel"? Greg
