Old 03-08-2016, 10:25 PM
Aero_Octaveus Aero_Octaveus is offline
Default Inboard tank rib tooling holes
Ok...Silly question here. I've been researching as much as I can but cannot find the answer. Do I need to worry about edge distance to the tooling holes when attaching the T-407 ring and the T-405 angle to the tank rib? Almost all of the build logs show the one rivet for the stiffener ring nutplate awfully close to that tooling hole. Don't know if I should rotate the ring slightly, but that affects the anti-hangup guide a bit.
Do I need to be concerned with the flop tube hole. My gut says I might be ok there.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
2020 Donation Current
http://garetsrv.blogspot.ca/
Old 03-09-2016, 09:48 AM
Ralph Inkster Ralph Inkster is offline
Not a problem. The holes are not stress points & the sealant you apply between the metal sandwich structure fills the holes in.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 03-09-2016, 09:55 AM
wirejock's Avatar
wirejock wirejock is offline
Default Problem solved
I was getting a headache trying to remember what I did there. Thanks.
Sucks getting old
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
