Old 02-22-2016, 12:53 PM
lr172 lr172 is offline
Default Assessing Brake Pad Wear
I have my wheel pants off for painting and thought I would replace my brake pads while off, but I realize that I don't know what thickness is considered worn out (i.e. near the rivets). My pads are currently the thickness of the backing plate (I think it is 1/8", but not sure). Can anyone give me guidance on how close they are to worn? If I need new pads, was hoping to order them before I go back to the airport next.
Larry
Old 02-22-2016, 01:06 PM
bkthomps bkthomps is offline
pads are so cheap, i just replace them when i have the calipers off for any reason, good insurance and peace of mind
Old 02-22-2016, 01:27 PM
flyboy1963's Avatar
Default a tip I learned here....
when I had the pads off, or installing new ones?...I mic'd the depth of the face of the pad to rivet distance....then filed a notch in the top edge of the pad to almost the same depth.
Thus at a glance, I can see how close I am getting to 'the rivets'....assuming fairly flat pad wear, which isn't always the case.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 02-22-2016, 01:39 PM
RV6_flyer's Avatar
Default RAPCO has wear indicator
RAPCO pads have wear indicators. See this thread for more details. It is almost the same as this new one.
I think the Cleveland brake min thickness spec is 0.100". Parker Aerospace (aka: Cleveland) give away a plastic thickness gauge at Oshkosh AirVenture booth that can be used as a go gauge as it is the minimum thickness.
One can also check the Cleveland Service Guide.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-22-2016, 01:49 PM
F1R F1R is offline
Most brake pads have a small instep at the ends, that indicate the max allowable wear. It closely represents the depth of the rivet head. Often your time is worth enough to change them every annual even if you have a bit of comfort left. It is faster and less costly than refacing the discs.
All I can add is that if you have Groves Discs and calipers,you will do very well to use Groves replacement pads.
ACS only had RAPCO pads. SO I used a few sets, however they have really coarse pieces of bronze that are far too aggressive for the groves discs. I hosed a set of discs prematurely learning the lesson.
The Groves pads do a fine job of braking as designed, with much less gouging of the discs.
The groves pads cost more than the rapco, but are worth every penny.
YMMV and good luck.
Old 02-22-2016, 01:50 PM
bkilby's Avatar
bkilby bkilby is offline
Default min 0.100" for lining thickness
Cleveland guide says "lining worn to a minimum thickness of 0.100" (2.54mm) must be replaced.
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 02-22-2016, 02:13 PM
jdeas's Avatar
jdeas jdeas is offline
Default Measure both pads
This is also a good time to look for even wear between inner and outer pad to confirm the caliper is floating properly. Always replace the pair if one is below .1"
JD
RV-7 N314SY (KWHP)
IO-360-B1B
A&P
CANbus based trim/flaps and electrical
Old 02-22-2016, 07:10 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I buy my replacement pads from Vans. I could be mistaken, but they appear to not have as much of the course metal content as the Rapcos. They last plenty long enough for me too. I try to use my brakes as little as possible too.
Neal Howard
Airplaneless once again...
Old 02-22-2016, 07:15 PM
Walt's Avatar
Walt Walt is offline
Most pads, for whatever reason, wear significantly more at the bottom of the pad than at the top, so don't be fooled by just looking at the top where its easy to see and think you have plenty of pad left.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 02-22-2016, 07:34 PM
In 1,000 hours, I've replaced my pads once and haven't replaced my disks. At last year's condition inspection, all was well within tolerance. At this rate, I may never need the replacement disks I have sitting on the shelf.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
