Old 02-18-2016, 07:27 AM
Default The problems with cheap 5v adapters
There have been a few posts regarding the use of the 5V cigarette plug chargers for mobile devices. One issue is that some of these generate interference in radios and other electronics.
The fact is they do.
Some are better made and better filtered than others.
I recently diagnosed an issue that was directly related to a noisy cheap 5V adapter (thankfully not in my airplane).
http://thesalmonfarm.org/blog/p/5790
I still like the convenience and flexibility of using a 5V cigarette plug adapter but I now keep "the good one" in the plane.
Old 02-18-2016, 09:31 AM
krw5927 krw5927 is offline
Very same thing happens in my wife's car. Tire Pressure Monitor System (TPMS) light comes on after a while of using a cheap cigarette lighter adapter. Took quite a while before I figured out what was causing it.
Kurt W.
RV9A
FLYING!!!
Old 02-18-2016, 09:46 AM
DHeal DHeal is offline
How does one distinguish the good plug-in chargers from the bad?
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
Old 02-18-2016, 10:01 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
One plugs them into Glen's car and checks the TPMS light.
Old 02-18-2016, 10:14 AM
Flyingleap Flyingleap is offline
Default Linear...
Does this mean we have to go back to the "7805" linear regulators instead
of the switchers just to keep noise out of our comms?
John
John R Prince
RV-7 want-a-b
Dues Paid for 21
Old 02-18-2016, 10:36 AM
N402RH's Avatar
N402RH N402RH is offline
Default Quality 5V Chargers
We use these in our panels:
http://www.commitlift.com/
Sometimes you get what you pay for.
Rob Hickman
Advanced Flight Systems Inc.
N402RH RV-10
Old 02-18-2016, 11:54 AM
jj13 jj13 is offline
Default Yep - I had the same problem
So I tried 2 different AUKEY's and both eliminated the noise problem I had with a previous brand.
http://www.amazon.com/gp/product/B00...ilpage_o01_s00
John
9A - 92129 / N1354J First Flight 5/2/2015
Dues paid
Old 02-18-2016, 06:43 PM
mantry mantry is offline
Rob Hickman
N402RH RV-10
I just flew with one of these in my RV7 on Tuesday, powered my iPad Air and charged my iPhone just fine. It is mounted under the panel then the two lightning connectors pass over the SCAT tube for the vent and are stored in the side pocket. WORKS GREAT! I'm happy!!!
Donation for 2019 complete! Thanks VAF and DR! (Worth every penny!)
Old 02-18-2016, 09:27 PM
brian257 brian257 is offline
Or install one of these and have two USB charging ports with a total of 4.2A and no interference at all. Full disclosure, these come from my company, but they work and don't have interference problems.
http://aircraftproducts.wicksaircraf...bchg?forward=1
http://www.aircraftspruce.com/catalo...lickkey=264635
Old 02-19-2016, 05:23 AM
rzbill's Avatar
rzbill rzbill is offline
Buy from an aviation related or other known source or take your chances.
I was at OSH a couple of years ago and saw a double outlet charger in Sporty's booth that was cheaper than many automotive units I have observed.
Bought it. Works great. It is in their catalog.
Last week I decided to add a permanent USB charger outlet because SWMBO has commandeered the current single 12V outlet. Just ordered from Stein. Do I expect problems from that unit? I don't think so.
Bill Pendergrass
ME/AE '82
