Old 02-17-2016, 02:56 PM
KatieB's Avatar
KatieB KatieB is offline
Default Engine mount wear due to cables
I found a few wear marks on the engine mount as I was taking the engine off the other day. There were PVC (I think) plastic shrouds around the cables in the areas contacting the mount to prevent them from rubbing, but it looks like they didn't do much good. I don't know if there was just a lot of grit that got down in between there or what.
This wear mark is after 450 hours of operation. I think it's just through the powdercoat, but I won't know til I clean it up some. There is a corresponding flat spot on the plastic. There are a few more spots like this as well.
So I post this as a caution to people who might think having the plastic protectors is all you need. And, I'd like to know if there's a better alternative that might not wear so badly. Is there a better material to use for this, or should I just be careful to keep the thing cleaner?
Katie Bosman
EAA Homebuilt Aircraft Council
Rebuilt most of SNF tornado victim RV-3B Tony Boy II (had to sell him, but he's flying!)
VAF Dues Paid 2021!
Thoughts & opinions expressed here are my own, and not those of my employer.
Old 02-17-2016, 03:21 PM
jdeas's Avatar
jdeas jdeas is offline
Default Grit
Same thing with zip ties. Relative motion and grit will do that.
I try to strap down anything that could move (rub). Also have a habit of placing a loop of Silicon tape on any surface before I strap something to it unless I am using an Adel clamp.
Time will tell if that was a good idea or not
JD
RV-7 N314SY (KWHP)
IO-360-B1B
A&P
CANbus based trim/flaps and electrical
Old 02-17-2016, 03:35 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I'm guessing that examination will show that the engine mount is fine Katie - but certainly check it to your satisfaction. For a crossing like that, I'd wrap the mount tube in silicone table, put a cable tie aroudn it, then loop another cable tie through the first at 90 degrees to the first to wrap around the control cable. That will add a touch of separation and also get rid of the relative motion. An Adel combination would better better, but sometimes the slack just isn't there to make that work.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-17-2016, 06:05 PM
KatieB's Avatar
Good suggestions.
As for cleaning this thing up, does anyone have experience with a good durable spray paint that's close to the Van's light gray powdercoat color?
Katie Bosman
VAF Dues Paid 2021!
Old 02-17-2016, 06:19 PM
rzbill's Avatar
rzbill rzbill is offline
Katie,
I wound up with a bottle of touch up paint in the color you want at the end of my build. Came from Vans. Take a look on their online catalog. That's bound to be where I got it.
Bill Pendergrass
ME/AE '82
Old 02-18-2016, 08:17 AM
KatieB's Avatar
OK, thanks. I'll check it out. I need a few other things from Van's too. Lord Mounts and a spinner kit...
Katie Bosman
VAF Dues Paid 2021!
Old 02-18-2016, 08:40 AM
Steve N.'s Avatar
Steve N. Steve N. is offline
Default Paint
If you want the grey in spray can, it's here.
http://www.flyboyaccessories.com/Sea...&Submit=Search
Steve
N174AS/2005/1000+hrs
Old 02-18-2016, 09:01 AM
bret's Avatar
bret bret is offline
One saying I read on here a long time ago, ( if it CAN chafe, it will chafe ), thanks for the photo and a heads up!
Old 02-18-2016, 01:15 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Where I suspect that any cable that I have not secured with a hose/wrap, standoffs & zip ties... I'll put a blob of rtv on it between the cable & the mount. Sort of like a big wad of bazooka gum.
This prevents any move movement that may occur against the mount area.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL
1240+ hours
Old 02-18-2016, 03:19 PM
bhester's Avatar
bhester bhester is offline
Default Adel to Adel
I agree with others if any way possible the best way is an adel clamp on the engine mount and another small one on the cable and both clamped together.
Good luck!
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2020 VAF donator - alot better than any magazine subscription
