Old 02-14-2016, 11:20 PM
Aircraft Specialty Aircraft Specialty is offline
Default RV-12 Canopy Lock Official Release
Aircraft Specialty is VERY EXCITED to announce the release of our Aftermarket Canopy Handle with integrated locking mechanism.
This has been a project that has been in the works for approximately two years. It has undergone beta testing and we currently have approximately 15 units in the field. Feedback has been overwhelmingly positive and we have made small refinements in the design over the past two years to bring this finished product to you.
If you go to www.aircraftspecialty.com, you will find more pictures of the unit as well as a detailed installation manual.
We also designed this unit in a unique fashion for ELSA builders. It is advantageous to have this handle on hand when doing your canopy installation, even though you have to utilize the stock vans handle for initial certification. There is more information in our installation guide.
We absolutely love building, innovating and designing new products. But, we couldn't do it without the help of our beta testers in the field who provide very valuable feedback to us. I would like to thank Dave, Jesse, John and Ken for their help with the initial beta testing and installation images.
We look forward to working with the RV community and continuing to innovate with new designs.
Please reach out to us with any questions that you have.
Steve
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.asflightlines.com
Old 02-15-2016, 02:13 AM
John-G John-G is offline
Default Aircraft Specialty's canopy lock is a winner!
I?ve been waiting for the official release of Aircraft Specialty?s RV-12 canopy locking system to post comments about the canopy lock. I had received one of the prototype units and promised Steve I would not post anything on the forums until the official product release.
Aircraft Specialty?s RV-12 canopy lock is a slick, eloquent design that is simplistic, easy to install and easy to use. The lock assembly and associated hardware is nicely machined, beautifully powder coated and complete with stenciling. It just looks great!
The production version utilizes a different locking pin receptacle than the prototype had (which could be locked accidentally by just pressing down on the locking plunger). Steve sent out the new version of the pin receptacle to replace the older version. The current production version of the pin receptacle has a safety feature that prevents accidental lockouts from occurring. This was accomplished by the addition of a spring loaded pin in the pin receptacle that prevents the locking pin in the canopy lock from entering the pin receptacle far enough to lock. Now accidental lockout is a nonissue because it requires two simultaneous actions to lock the canopy latch handle. To lock the canopy, the spring loaded pin attached to the pin receptacle needs to be pulled outward while simultaneously pressing down on the plunger in the lock ? very slick!
I?m very pleased with the canopy locking system and would recommend those considering a canopy locking system for their RV-12 to give Aircraft Specialty?s solution a close look.
John
http://www.dogaviation.com/
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 02-15-2016, 08:55 AM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default One question
I generally think this is a pretty slick design. The only concern I would have is that it appears you can lock things without the key, by pushing a couple of buttons. I'm wondering, could someone push the buttons and lock you in the cockpit? (Just because I'm paranoid doesn't mean they're not out to get me!)
Rob Reese
RV-12 #120332 N73HR
Austin, TX
TangoFlight Mentor
Old 02-15-2016, 10:13 AM
Rob and all. This is an excellent question. We will have more pictures and video of the receptacle lockout mechanism in operation eventually, but we are awaiting some better pictures/videos from customers who have them installed.
You will be able to lock the aircraft without a key. However it will require pulling and holding out the lockout pin while simultaneously pushing down on the lock mechanism. The lockout pin is quite small and in this picture has not been threaded into the receptacle fully yet. But, essentially you will have a spring loaded pin that blocks the receptacle from access by the lock. The knurled knob needs to pulled and held outward which clears the hole to allow you to press the lock mechanism in.
This eliminates any potential inadvertent locking of the canopy. MOST IMPORTANTLY, it eliminates the possibility of a misguided and wayward bird form thinking your shiny new handle is a tasty treat and pecking it closed accidentally.
I do like when you wrote "Just because I'm paranoid doesn't mean they're not out to get me!" There is truth in that. If someone knows that you have this lock, knows how to use it, and then decides to walk up to your airplane with you inside, reach up and lock you in, my suggestion would be to strongly evaluate your base of friends!
Hope that information helps. Initial response to this release has been very positive and we look forward to hearing from everyone after installation. We will do our best to monitor this thread and answer questions. Or, you can always email us at aircraftspecialty@gmail.com for a quicker response.
Steve
Old 02-15-2016, 10:28 AM
Default Yes - But it would be intentionally
Is it possible to get locked in? Yes.
But that said, it would be an INTENTIONAL malicious act. The spring loaded pin that prevents the lock plunger from dropping into the pin receptacle MUST be pulled and held outward with one hand, while simultaneously pushing down on the locking plunger with the other hand.
I plan on keeping a spare key in the glove box which could be passed through the air vent should such an unlikely event occur ... then pick better "friends".
John
Now Flying!!
Old 02-15-2016, 10:39 AM
PilotBrent PilotBrent is offline
Default This could be spun as another benefit...
Hey Honey, I mean't to come home earlier but someone locked me in my RV-12 and I had to go flying instead
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
2021 VAF Donation, please make yours too!
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 02-15-2016, 10:54 AM
RFSchaller RFSchaller is offline
I like it, but there are scenarios where you can lock yourself out. I put a desk lock on the fuselage with a hooked lever that engages a slot in the canopy rail. I have to have the key in hand to lock it, so there is no chance of ever locking myself out unless I lose the key!
My friend has an SLSA RV-12 with an expensive dual G3X system. He doesn't leave his plane on any ramp overnight because he can't lock the canopy. Granted a determined thief would break a canopy, but at least a lock on an SLSA would deter some. I don't understand why Vans has not put a lock on the canopy.
Old 02-15-2016, 11:16 AM
All designs have trade offs. With this canopy handle lock, you don't need a key to lock the aircraft. If you did lock both your keys into the aircraft, the handle can be removed utilizing certain tooling. I won't describe the process on a public forum. But, I think a crook with a drill and a bunch of tools would raise suspicion while he was trying to enter your aircraft. If you lose the keys with a desk lock on the fuselage in the locked position, you may damage the aircraft while trying to get in.
I guess the key (no pun intended) with any lock mechanism is to not lose the key and to have a spare key. If you have a key, there is no way to get locked out of the aircraft.
Old 02-15-2016, 11:18 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Looks like a fancy key - how difficult to get spares?
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 02-15-2016, 11:20 AM
For those of you who would like to pursue this option, we will sell the old style receptacles and provide a pdf of fbo phone numbers to arrange for a line guy to "maliciously" lock you in your aircraft so you have no option but to go flying!
