Old 02-11-2016, 09:00 AM
pmshep pmshep is offline
Default Pair of 14A's
Hanging around the hangar at DVT awaiting FWF kits........
Old 02-11-2016, 09:35 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default Twins!
A nice way to build - you can check each other's work.
Mark
RV-9A; Built, Flown & Sold
RV-14A; Building
2021 =VAF= donor
Old 02-11-2016, 01:29 PM
vanduyn vanduyn is offline
Default FWF kit
I am a bit further along than you, also waiting for the FWF kit. I would be interested to know how many other 14 builders are also waiting for there FWF kit. Van's will not commit expect to say soon.
Old 02-11-2016, 01:49 PM
Jaws Jaws is offline
Nice...If I didn't know better I think you were building in CA
Larry
Jaws
Rupester Rupester is offline
Very cool. Until this moment I had not seen the new shock absorber arrangement on the nose strut.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 02-11-2016, 02:16 PM
DanH's Avatar
DanH DanH is online now
Like those stands under the spar stubs. Custom bracket at the top of the screw, pinned through the spar?
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-11-2016, 02:26 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Looks a lot like the setup on the 10.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-11-2016, 02:27 PM
Ron B. Ron B. is offline
Add another to your list. Soon is getting old!
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 02-12-2016, 05:12 AM
Gahannaflyer Gahannaflyer is offline
I too am anxiously awaiting the FWF kit. I understand that it has got to be very frustrating for the Engineers at Vans. I also DO NOT suspect that that they are 'holding up' for any misguided reason. There is probably no one else wanting the FWF issue to be put to bed more than the Vans guys. I am just doing a lot of loose end stuff. I do wish that they would release section 52 instructions (antenna installation) so that I can get that section done. It is looking like it will be more and more difficult to be finished for a big unveiling at OSH16. Happy thoughts huh? There are probably a few brave soles that are forging on, 'blazing the trail', sourcing out what would normally be in the FWF kit. Good luck to them. I want to be one of us to shake the hand of the builders that are at OSH16 with their 14. Maybe I can take some pictures of these fine folks. Looking forward to the pilgrimage to aviation Mecca (OSH16).
