Old 01-18-2016, 10:16 AM
flyboykelly's Avatar
flyboykelly flyboykelly is offline
Default RV-8R second test flight prelim data.
We had a successful and event free test flight number two today!!! Prelim numbers show a cruise speed of 155mph at 23" of mp and 3000 engine rpm. This is 15 mph faster than my initial design goal. This is also only 15 mph slower then my fathers 200hp RV-8. These speeds would not have been possible without the use of the GT electric prop. After shutdown I laser checked the cylinder head temps. None of them were over 200f. The baffling is doing its job quite well! Time to de cowl and do a visual inspection and filter check. Video is posted below.
http://youtu.be/fSLpesAVVuw
Flying as of 1-12-2016!!!!!
Old 01-18-2016, 10:28 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
So sweeeeeeeeeeet
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-18-2016, 10:46 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
My only beef with these videos is that it was -12C here this morning and seeing those palm trees and sunshine is annoying
I love the look and sound of that airplane! I'm jealous...
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk (C-GPFG reserved)
Flying a '79 Maule M5-235C
Ex-military : Donated anyway (it's worth it)
President EAA 245 Ottawa, ON
Old 01-18-2016, 10:59 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by flyboykelly View Post
We had a successful and event free test flight number two today!!! Prelim numbers show a cruise speed of 155 mph at 23" of mp and 3000 engine rpm. This is 15 mph faster than my initial design goal. This is also only 15 mph slower then my fathers 200hp RV-8.
155 MPH, or 155 knots?
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-18-2016, 11:40 AM
155 mph cruise
Old 01-18-2016, 04:55 PM
Sure is a good looking airplane, Brian.
Congrats on the build and success of flying it.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 01-18-2016, 06:13 PM
Weasel's Avatar
Weasel Weasel is offline
155 mph cruise
Is that with the left ball to the wall?
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1700hr counting
RV-10 N7631T 820hr Sold
RV-8 700+hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 01-18-2016, 06:33 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Radial benefits...
all cylinders should theoretically get equal and instant cooling when airborne if baffling is working properly...they just like to leak a "little oil" in the bottom cylinders...I miss the Wright radials we had on the S2F,Wright R-1820-82WA radial piston engines developing 1,525 horsepower each...
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 01-18-2016, 06:50 PM
meloosifah meloosifah is offline
I am not seeing a lot of 200hp RV8's cruising at 3000 rpm and only hitting 170 mph. Just sayin'. The -8 you are comparing to must be a monster dog. Not taking anything away from your radial - that thing looks awesome!
RV7a (converting to TW and then ready to install the engine and panel)
1946 Cessna 140 (currently flying)
1946 Piper J3 Cub (stripped for restoration)
Exempt on multiple counts - donated double because this site is worth it!
sapeloson's Avatar
sapeloson sapeloson is offline
Default Congrats!
Super Cool!
RV-8 N84TH
Garmin IFR by Stein
Lycoming IO-360 (180HP)
MT 3 Blade CS
C-182 N3159F
