Old 01-02-2016, 10:26 PM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default O340 first flight
RV8 first flight
Jeff Reins's RV8 flew this evening! He used a ECI. O-340 Stroker rated at 177hp.
I was the pilot. I am impressed with this engine in Jeff's RV8!!! He has A Hartzell prop. The airplane weighed in at 1047.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 01-04-2016, 11:09 AM
Warden Warden is offline
Jay,
Please tell Jeff Rein's I said congratulations! I purchased his RV-7 empennage section a couple of years ago.
Thank you,
Jeff Shaud
Old 01-04-2016, 12:08 PM
N941WR's Avatar
N941WR N941WR is offline
You once told me that a light O-320 powered -8 flew as nice as a -4. I would think that an IO-340 powered -8 would be a good compromise between light handling and gobs of power.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-04-2016, 05:59 PM
jclark jclark is offline
Originally Posted by Jaypratt View Post
RV8 first flight
Jay,
Which Hartzell prop is he using????????
Thanks!
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 01-04-2016, 10:06 PM
Jaypratt's Avatar
Default Lite weight 8
James, and Bill,
I only have 15 minutes on this engine prop combination? The plane excelaration was extra! !!! With 20 gallons of gas.
The prop is a Hartzell HC-C2YR-1BF
Jeff's RV8 has a standard 'heavy' tail wheel. It has the steel standard gear.
I would like to try building a light weight RV8 with Grove Aluninium gear, with Dayton's tail wheel, and a Cato Prop, and the Cubcrafters light weight O-340 sump / engine.
In 1999 I finished a RV8 with O-320 and a wood prop, 1046 pounds,,, the handeling was supper nice. But climb performance was so,so,,,Jeff's airplane,,,, first impressions,,,, are Great! Very similar to my old 8 except better ! With the extra horse power.
Lighter RVs are more fun!
Jay Pratt VAF #2
Old 01-05-2016, 08:05 AM
Mel's Avatar
Mel Mel is offline
James, and Bill,
Don't forget the CubCrafter's O-340 is rated at 80 hp continuous.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-05-2016, 09:49 AM
Jaypratt's Avatar
Default Mel
Mel,,,,,,, You just know too much.
Jay Pratt VAF #2
Old 01-05-2016, 10:30 AM
Mike Macon Mike Macon is offline
So is the Titan 0-340. Are you saying it can not be run above 80 HP continuous in an experimental non-LSA aircraft?
Mike Macon
RV6A
Carbon Cub EX
VAF #201
Old 01-05-2016, 11:24 AM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
Their engine is only rated that way for the Light Sport Rule. It is a 180 hp engine and if you build the plane as an experimental, place the throttle where you want and for however long you want. You can fly at 45% all day too. Their 340 would be great on any RV.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 01-05-2016, 11:36 AM
Mel's Avatar
Mel Mel is offline
No; I was being facetious! Simply yanking Jay's chain.
You can exceed manufacturer's limits all you want in an experimental amateur-built aircraft.
