Tank attach bracket safety wire
rightrudder
Where did you guys anchor the safety wire on the drilled-head bolt on the tank attach bracket? If anyone has a photo, that would be great. Thanks!
Just drill a small hole in the aluminum AA and safety wire it to that.
Yep, drilled a hole through the angle right next to the bolt.
Similar to what I did for the bolt on the end of the axle that holds the main wheel pants on.
Only I used the end of the large cotter pin for the wheel pant bolt.
Here's a photo of mine.
