Old 11-29-2015, 07:54 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default Don't drop that BUCKING bar!
I seem to remember a post not too long ago asking for advice on how to smooth out a dent in a leading edge that was the result of dropping their bucking bar while riveting the leading edge skin to the LE ribs. While assembling the outboard leading edge skin and ribs today, that came to mind while handling a nice heavy tungsten bar inside the leading edge and having it slip in my hand a little and almost dropping it.
I cut some corrugated cardboard pieces to fit between the ribs to cover the leading edge on the inside and about 6 inches high on each of the top and bottom of the skin. Dropping the bar would likely not put a dent in the leading edge - I didn't do a test. Pretty simple and a good safety net.
Looking down into the leading edge at a resting tungsten bar. The cardboard is cut to expose the rib edges so they can be bucked without removing the cardboard.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
RV14A (N14ZT), Ser#140195
Start 10/11/14; AWC Rcvd 7/21/21
Contribution made 12/2/20 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 11-29-2015, 08:09 PM
wirejock's Avatar
wirejock wirejock is offline
Default Idea
Good idea.
I taped a leash on mine.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 11-29-2015, 08:14 PM
g zero g zero is offline
Default Bucking bar
If you stand the leading edge assembly on end its easier to rivet , and no chance of damage if you drop the bar .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
Old 11-30-2015, 11:13 AM
BAK613 BAK613 is offline
Did you Alodine those LE Ribs?
Bruce
Bruce Kaplan
Burke, VA
RV-14A pre-build stage
N613BK reserved
Old 11-30-2015, 07:41 PM
russ-e russ-e is offline
If you ware a latex type glove when holding a bucking bar it is a lot less likely to get dropped. It is hard to believe how easy it makes it.
Old 11-30-2015, 08:45 PM
jeffw@sc47's Avatar
Bruce
Bruce, it is a PPG industrial coating - Spectracron (QAP701 and QAP702), a two part etching primer. It is equivalent to the Sherwin Williams primer that is used on the QB kits by the Philippines assembly subcontractor.
Jeff Warren
Old 12-01-2015, 07:27 AM
flynwest flynwest is offline
Default Bucking Bar cover
I cut a little piece of bicycle inner tube and put it over the bucking bar to help both hold on to it and a little cushion just in case it falls.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
RV 8 Fast back built and sold
RV 10 Building
Dues paid 2022
Dan "Nordo" West
Old 12-01-2015, 08:54 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
I have a bundle of sheets and blankets that I put under wherever I am riveting. Except when I forget to put them there and drop my bucking bar anyway.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
