Old 11-16-2015, 07:09 PM
thoma015 thoma015 is offline
Default Rudder stiffeners not lining up
I am having trouble with my rudder stiffeners lining up. It seems like to me that the holes in the stiffeners are uniformly spaced, but the holes in the skin aren't.
The skins are older from a older kit i bought from a guy and the stiffeners are new from Vans (the kit didn't come with them).
The stiffeners holes are more widely spaced than the holes in the skin, could i flute the stiffeners to get them in line?
-Hawk
Old 11-16-2015, 07:20 PM
wirejock's Avatar
wirejock wirejock is online now
Default Fluting
The holes are off lenthwise. Fluting won't change that.
Try moving them to other places or starting clekos in the middle.
I don't think the holes changed. That looks like a mis punched part but I am usually wrong. Experts here will know.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 11-16-2015, 08:31 PM
You can buy blank stiffener angle from Van's, cut them to length yourself, and drill them yourself, just like us RV-3B builders do. Takes a little time but it isn't a big deal.
Dave
Old 11-17-2015, 06:37 AM
blueflyer's Avatar
blueflyer blueflyer is offline
If I recall, it took me several iterations to figure out the proper placement of the stiffeners. Just keep looking at it, you'll see how they fit. And as already pointed out, if you goof up your stiffeners in the process, you can buy more from Vans.
Old 11-17-2015, 07:43 AM
jaradtke's Avatar
jaradtke jaradtke is offline
It looks like that stiffener is in the wrong sequence
Jeff Radtke
Lutz, FL
RV-7A - SOLD
RV-7A - New Build
Tail Feathers - Complete
ER Wings - Complete
Fuselage - Complete
Finish - Started
Old 11-17-2015, 10:41 PM
nbachert nbachert is offline
The -7 rudder changed a few years back didn't it? Maybe the stiffeners are from the newer rudder while the skins are from the old one.
Old 11-18-2015, 01:16 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Seems like I remember if you turn them the other way they will line up. You may have to try different stiffeners in different locations but eventually they will line up...and you'll have one of those DUH moments. 😀
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 11-18-2015, 07:32 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
They are all cut at a notch in a long piece of AL that is pre punched. You need to cut them apart, then find the correct location where the holes and length line up, Then the ends are tapered accordingly. I think everybody gets a little confused over these.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Porsche Boxster 718
