Old 11-13-2015, 12:14 AM
AX-O's Avatar
AX-O AX-O is offline
Default Starter Failure
I had a failure on my starter yesterday. I won't post the name brand yet as I sent it in and will wait to hear back. It is one of those light weight starters without a Bendix. The starter has less than 25 starts on it. The engine is a IOX-340 with 9 to 1 pistons.
Yesterday I attempted to start my airplane. I hit the starter and the prop turned without issues. As I let go of the starter the engine caught about 3 firing cycles but I was not able to keep the engine running (still learning this fuel injection thing).
After all motion stopped, I re-attempted. Nothing... My MFDs flickered and the prop did not move. "What is going on?" I tried it again and I observed the same outcome.
Got out of the plane thinking that the prop did not want to turn because it got stuck at the top a compression cycle. "I'll just move the prop and try it again". To my surprise the prop was stuck and I could not move it. My heart just sunk. "oh boy, here we go".
Got the plane in the hangar (luckily it was at home) and took the cowling off. After inspection, I determined that the starter failed (pictures below). Spent the next hour removing the 4 nuts that hold the starter. Has anyone seen this failure before? The starter gear would not retract or turn at all. It was jammed. No damaged to the starter gear or the starter ring. The company tech told me that in over 60,000 units this is the first time he has heard of this. I am sure I am not that lucky.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weigh out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk. Further more, these are my opinions and not those of my employer.
Old 11-13-2015, 03:43 AM
flightlogic's Avatar
Default starter woes
Has it been working well for you before? The teeth do not look properly engaged in the photo. Just wondering if it is the proper starter.
Good thing you were not out cross country when it failed. Keep us posted on the results.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 11-13-2015, 07:05 AM
RV6_flyer's Avatar
Default Starter Solenoid
Have not heard of any failures such as the one you have.
The light weight starters have had good and bad service history. The solenoid has been a weak part on some of the starters.
I ran a light weight permanent magnet starter for around 2,000 hour with only one solenoid replacement. A friend (based not far from you) had replaced his solenoid every several hundred hours over the same 2,000+ hours. Following manufacturer's recommendations, I sent the starter in for overhaul but the unit was too old to be overhauled so was sent a newer overhauled replacement. The replacement was eating solenoids about every 50-hours. After replacing 3 solenoids and needing a 4th, I sent the starter in and upgraded to a better starter that used less starting current and was a little heaver.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-13-2015, 07:15 AM
olyolson's Avatar
olyolson olyolson is offline
Default Starter
Axel,
I went through several of the "lightweight" starters on my engine before the company gave a trade in allowance to upgrade to the high torque NL model. Never had a lick of trouble since. The lightweights seem to be better on 320s but some guys have had good success on the 360s. With my AEIO-360 and a C/S prop the little starter just couldn't hack it.
Oly
RV-8, Aerosport IO-360M1B, MT 3 blade, AFS 5500
RV grin every flight
"Sure is nice to have smart friends"
Old 11-13-2015, 08:02 AM
Toobuilder's Avatar
Although I've never seen a starter (especially a new one) lock up like this, I certainly HAVE heard a vendor say "...I've never seen this failure in xx years..."
Seems like any time I've had a component failure go back to the vendor it's "the first time...". I'm glad (in a sense) it's not just me.
To your situation though, it sure seems one of those "way outside standard deviation", infant mortality things. Let us know what the vendor says.
And to Oly's point above. I had that same starter on my 540 but traded it in on the NL. So far so good.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-13-2015, 09:01 AM
AX-O's Avatar
No issues before.
My buddy was saying since i do t have the starting procedure down quite yet that i may have damaged the starter due to the motor going to high rpms right after starts.
Axel
Old 11-13-2015, 09:08 AM
blueflyer's Avatar
blueflyer blueflyer is offline
If you drain your battery while trying to start your plane, the starter will stay engaged like that. I know that from experience...
After charging my battery and trying another restart, it all worked as it should and the starter retracted after starting.
Old 11-13-2015, 09:16 AM
aerhed aerhed is offline
It's a new 340, so it should have a 149 tooth ring. That looks like a 122 tooth ring. Am I wrong?
Actual repeat offender.
Old 11-13-2015, 09:34 AM
krw5927 krw5927 is offline
Nope, you're not wrong. Definitely looks like a 122 tooth ring gear to me.
http://www.skytecair.com/RingGearTech.htm
Hopefully, Axel, you have the proper starter for a 122 tooth ring gear. Your photos make it look a bit questionable, but it could just be the angle the photo was taken from. Like others have said, the NL starter I purchased used has been flawless. Especially given the high compression 9:1 pistons of the Titan OX-340S (same engine I have, BTW). The NL starter just powers right through the compression stroke.
Kurt W.
RV9A
FLYING!!!
Old 11-13-2015, 10:48 AM
AX-O's Avatar
I will swing by the airport and check the battery. Thank you.
It is a 122 tooth ring.
I have the right starter, 122. I think the pictures/angles may be faking the eyes. I am not sure if I have enough room for an NL starter. I have a fuel line that may interfere. Hopefully it was not a dead battery and I sent the starter off for no reason.
Axel
