swisseagle
I’m short before the first engine run, what a task after 11 years of building!
Now the BIG question: What should be done to not harm the engine?
Mattituck TMX-IO-320, red gold
Roller tappet
AFS Fuel Injection
2x P-MAG
Sensenich metal FP
- Is there a Lycoming paper that describe this?
Otherwise I was thinking of this, but unsure:
- Drain anti rust oil, put a new oil filter on, refill with straight mineral oil (Phillips 20W50).
- Remove bottom spark plugs, drain any oil from the cylinder.
- Rotate propeller (x times?) to fill up the oil-system (filter, oil galley’s)?
- Check correct timing on the 2x P-MAG’s.
- Put in clean and proper gaped spark plugs.
- Purge the oil-pressure-line up to the pressure sensor?
- Purge the fuel pressure line up to the pressure sensor?
- Disconnect fuel line at the throttle body, flush fuel system with el. fuel pump, reconnect line.
- Fully charge the battery.
- As last step, connect the starter back again.
For sure also this:
- Put chocks under the wheel’s.
- Prepare fire extinguisher.
- Instruct ground crew.
- Mentally go thru engine start sequence.
- … wake up the engine and enjoy![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Did I missed something?
The pictures are not brand new. In the mean time, the FWF section is finished, prop and spinner are on
Roller tappet
AFS Fuel Injection
2x P-MAG
Sensenich metal FP
For sure also this:
![IMG_3227.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-o5JD8KV2hNY%2FVgG5O4c5MGI%2FAAAAAAAAAZY%2F2Qt23tYPhxI%2Fs640-Ic42%2FIMG_3227.jpg&hash=8075f59d410fff5391a12f8d21a718be)
![IMG_3229.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-i_mmL7quPtQ%2FVgG5Pm6YYDI%2FAAAAAAAAAZg%2FUBJrmQVPndc%2Fs800-Ic42%2FIMG_3229.jpg&hash=7452ad93bf3f8cc1c2a0baad220b8c76)
![IMG_3231.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-0zGK4lCclXE%2FVgG5PEW8cUI%2FAAAAAAAAAZc%2FWDpCixxwJlA%2Fs800-Ic42%2FIMG_3231.jpg&hash=062463d4620009fc10c3e4c6d62682ac)
