swisseagle
Hello,
I know, many times asked here, but no precise answer ...
The Aeroquip aluminum fittings use this table: http://vansaircraft.com/pdf/Torque_Spec_Aluminum_Fittings.pdf
The aluminum tube to AN fitting use this table: AC 43.13-1B / TABLE 9-2. Tube data
But what the heck should I use on these, engine fuel pump fitting on the o-ring jam-nut:
Thank you for any input!
![cat-med_pump-fittings.jpg](/proxy.php?image=http%3A%2F%2Fvansaircraft.com%2Fimages%2Fcatalog%2Fcat-med_pump-fittings.jpg&hash=e95874c39f671f5c1132f350feb822e0)
