Old 01-06-2015, 09:10 PM
mv031161's Avatar
mv031161 mv031161 is offline
Default Alternator Failure
This is what happens to your brand new Oddissey Battery when your Suzuki Samurai Alternator Internal Voltage regulator fails and it ouputs 18 volts! I will reccomend a B&C Voltage Regulator to the RV8 Owner next!
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 01-06-2015, 10:40 PM
unitink72 unitink72 is offline
From what I've gathered from aero electric, a crowbar over voltage module would have saved your battery
Old 01-06-2015, 11:54 PM
erich weaver's Avatar
The B&C voltage regulator referred to in the original post has built in over voltage protection, which I believe is the point being made there.
erich
Old 01-07-2015, 06:45 AM
flyinlee flyinlee is offline
Default voltage regulator
Sorry, but what is a "B&C''.
Old 01-07-2015, 07:45 AM
TX7A TX7A is offline
http://www.bandc.biz/index.aspx
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 01-07-2015, 04:02 PM
DennisRhodes DennisRhodes is offline
Default over voltage protection
Does anyone know of a supplier for a "free Standing" 14 v system over voltage protection module aside from the built in models usually included with the Alt or external regulator?
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 01-07-2015, 04:08 PM
380mxc's Avatar
380mxc 380mxc is offline
http://www.bandc.biz/over-voltageprotectionmodule.aspx
Tim Emig
RV7
As I hurdled through space, one thought kept crossing my mind - every part of this rocket was supplied by the lowest bidder.
~ John Glenn
Old 01-07-2015, 04:21 PM
How does that wire in ? Has some pretty small looking wires on it. The wiring diagram did not open up on the B&C site.
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 01-07-2015, 04:37 PM
Sam Buchanan's Avatar
been here awhile
Dennis, this module will protect an externally regulated alternator. It is connected to the field wire between the circuit breaker and regulator. When it senses high voltage it shorts the field circuit to ground which pops the breaker taking the alternator off line. This happens in milliseconds.
There is a way to use the module with an internally regulated alternator but it requires additional components. Details are in Bob Nuckoll's book, The AeroElectric Connection.
Sam Buchanan
RV-6
Old 01-07-2015, 04:53 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Or an overvoltage annunciator. Second most critical to a low oil pressure annunciator. Looks like that battery cooked for a long time.
