Old 12-26-2014, 02:38 PM
JRo JRo is offline
Default RV-12 engine compartment fire
Guys,
I was running my engine today prior to flight, waiting for the oil temperature as always. SkyView warned "Shutting down in 30 seconds" and "Aircraft Power Lost". I shut down immediately, smelled smoke, then saw smoke at my feet. Exited the cockpit, peeked through the oil service hatch, saw yellow flames about 3-4" tall burning gently at rear of engine, straight below GPS antennae about 7". Extinguished immediately. Removed top cowl. Disconnected ship's battery. Fire appears electrical, but cause unknown. Pitot tube melted away for about 6" section (that appears to be mostly the combustion). Wire bundle severely compromised. Both throttle cables and both choke cables badly burned where they're bundled together and tie-wrapped to motor mount about 6" forward of firewall.
The hits just keep on comin'!
Jim
N448JR
Old 12-26-2014, 02:41 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Wow, Jim, if it had to happen, I'm glad it happened on the ground where you had options. Let us know what you find.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2022 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 12-26-2014, 04:14 PM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Originally Posted by JRo View Post
Guys,
Jim
N448JR
Very sorry to hear about the fire, I know that is discouraging.
Since the throttle and choke cables are fried the first thing that comes to mind is that something is wrong with the engine to airframe ground strap. If that ground is compromised, the electrons may decide the control cables are the easiest path to ground.
Sam Buchanan
RV-6
Old 12-26-2014, 04:16 PM
BigJohn BigJohn is offline
Scott McD. See my PM.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
Master Pilot Award, UFO Member.
RV-12 N37JP 120176, built 2011, sold 2020.
One Week Wonder Build Team, OSH 2018.
Old 12-26-2014, 08:35 PM
RFSchaller RFSchaller is offline
Very sorry to hear this. These are our babies. It's terrible to hear something like this. Please let us all know when you find the cause.
Rich
Old 12-26-2014, 11:12 PM
Driftdown Driftdown is offline
Jim,
Very sorry for your loss.
That withstanding, it was good that nobody got hurt and you had not departed yet.
It's just metal, rubber and plastic . . . and it can all be replaced.
When it is all sorted out, please let us know what happened.
What you find out may help another operator avoid a similar situation.
We are all here to help each other out.
Old 12-27-2014, 10:45 AM
cactusman's Avatar
cactusman cactusman is offline
Guys,
Jim
N448JR
Any info on the source of the fire yet?
Will you have to make an NTSB report?
Between this and another reported brake fire on another Van's airplane, I am glad I picked up that small fire extinguisher from ACS.
Glad the only damage is wiring and pitot tube, those can both be replaced!
John
RV12 Built and Flying
RV10 Started
Old 12-27-2014, 11:51 AM
DHeal DHeal is offline
I think Sam B's thought re: throttle cable/choke cable acting as a primary GROUND may be on-target. That or possibly a shorted power wire chafed through at the firewall?
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,100+ hours (as of Dec 2021)!
VAF donation through June 2022.
Old 12-28-2014, 05:12 AM
Geico266's Avatar
Geico266 Geico266 is offline
I would think a shorted wire would have popped a breaker or fuse somewhere.
I would think the OP would have found the cause by now.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 12-28-2014, 08:29 AM
JRo JRo is offline
It looks as though the wire from the starter relay to the cockpit switch panel became compromised. It is NOT fused. It is "hot" whenever the master switch is on. The insulation melted off this wire like a snakeskin from the starter relay to the point where it crosses beneath the choke cable, and heat became excessive, but very local. Damage was to the firewall forward wire harness, choke cable, throttle cable, pitot tube forward of the firewall, and GPS antennae cable (which is permanently attached to the GPS antennae). Damage was all contained in a very small area, and would likely not have spread, especially once the master is switched off.
Fire extinguisher should always be handy. But remember, an extinguisher which operates through suffocation of the fire will also suffocate the occupant(s) of a small enclosed area, like the RV-12 cockpit.
Jim (the guy with the fire)
N448JR
