Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
12-19-2014, 05:23 PM
To drill or not to drill, what have you done?
Photo: The R-606PP Reinforcement Plate clico'd between the flanges of R-902 Rudder Spar, and with the R-405PD Rudder Horn behind them. Notice the two undrilled holes in the Spar. Those two holes were factory drilled.
Photo: Same three parts shown from the Rudder Horn side. Note again two factory drilled holes in the Rudder Horn are undrilled in the Spar.
My natural assumption would be that these holes should be match drilled in the Spar to either the Reinforcement Plate or the Rudder Horn before riveting. However:
1) These two holes do not appear anywhere that we could find on Rudder DWG 7, Revision 5. Drawings of the three aforementioned parts and the builder fabricated R-917 Shim that fits between the Spar and Rudder Horn do not show these two holes.
2) The written instructions for Rudder construction do nowhere mention the two holes. The three clico'd holes next to them are specificalled out for match drilling to the spar.
With the holes not shown on the drawings and not mentioned in the instructions, while three holes next to them are, I became confused and telephonedf Vans for clarification. I was told the two holes are "most likely tooling holes" and not to drill them.
Is this a potential gotcha? What did you do?
Karl Bambas
karl@bambas.com
1954 1st solo
1964 Mooney Statesman, 1979 C-172, 1948 Globe Swift (all sold)
RV-7 "Dream Weaver" N50KB
Empennage arrived 10/14
QB Wings & Fuselage arrived 06/15
Finish & FF kits arrived 11/15
Dual screen Garmin G3X instruments and harness delivered by Stein 01/16
First flight June 13th 2018
2023 Dues Paid
Builders Log
Family Blog
12-19-2014, 05:49 PM
Holes
Those holes are not on my rudder parts or plans. I assume they are for another m9del and suggest leaving them. When in doubt, ask Vans.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
12-19-2014, 05:57 PM
Senior Curmudgeon
Do the holes in question line up in the reinforcement plate, and the rudder horn if you remove them from the spar??
Have you looked farther ahead in the plans to see if these are addressed later--------or if there is something that is going to be in the area that would interfere if there were rivets there?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-19-2014, 06:04 PM
I matched drilled the spar for those holes and added rivets, but I also made a new larger shim that included the two extra holes.
12-19-2014, 06:27 PM
Same extra holes on the recent 8 rudder parts...no reference in plans. Plans have you create a shim for one set, not both. I just made the shim wider as well and riveted all. I looked at my current flying 8 and the extras are not there. Change must have been made some time this year.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
12-19-2014, 06:44 PM
Gotcha
Karl
Welcome.
Would you please post Vans response and maybe a link to this thread to the new "Sticky" thread so others coming along will benefit? Use a subject line with the part number and plan page to make it easier to search. Thanks
Larry Larson
Estes Park, CO
Disclaimer
02-24-2015, 03:37 PM
To drill or not to dril RV-7 Rudder R-606PP and R-405PD
Hi all,
I have a similar problem. From the research on these forums I can only deduce that the parts changed some time in 2014. But the plans received (delivered to me in Late 2014) do not show the extra 2 holes in these parts.
It would seem loking at all the web blogs, these holes do not exist in any builders parts prior to this time. I have also checked with many builders in Australia. I asked them to go and look.
But I see on this thread there are several builders around that have parts with these extra two holes.
What decision have other made in this scenario?
Kind regards,
Anthony
02-24-2015, 07:14 PM
Mine's a 9A, and it has the extra holes as pictured. I elected to match-drill and rivet these holes and the shim. Van's is the final word of course, but there's plenty of material there, no interference issues and the rivets are widely spaced.
Doug
RV-9A "slider"--sold in July 2021
Donation made for 2021
02-24-2015, 09:53 PM
Just looked up those P/N on the RV-14 plans and sure enough we have them. The extra holes are all used in this model. Same part used in different airframes.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
02-24-2015, 10:54 PM
Thanks very much guys. It is good to have this clear in mind before kicking off wiht the drill. I really appreciate your response.
I am just finishing my VS and Rudder - so still a new builder.
BTW - seems to be a great forum. Hoope to return the favour to other newbies when I am further into the build.
AJ
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
