Just started install G3X touch into RV7. The display has a spot which would accept the GSU 25 on the back. However since the panel is tilted forward the orientation of the GSU25 would also be tilted. Is anyone aware if one can use this location successfully perhaps by adjusting for the tilt in the configuration set up? Thanks Gary
