Old 05-13-2014, 07:31 PM
n38139 n38139 is offline
Default Checkerboard Rudder
I have seen several checker board tail paint jobs and was wondering what size the average block is?
Old 05-13-2014, 07:33 PM
Paul Tuttle's Avatar
Paul Tuttle Paul Tuttle is offline
4 inches for mine.
Paul Tuttle
RV 8
C-FPVT
Flying.
Old 05-13-2014, 07:44 PM
On my RV-6, I made the checkerboard 3 columns wide, with the blocks getting wider from the top of the rudder to the bottom.
Here's a pic:
http://www.airport-data.com/aircraft...000906214.html
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-13-2014, 09:01 PM
Paul K Paul K is offline
2" but mine are ghosted and I was going for a different effect.
Paul K
West Michigan
2021 donation made, exempt but worth every dime!
Old 05-13-2014, 10:09 PM
Arie's Avatar
Arie Arie is offline
Could someone describe how you mask your rudder for a checker board paint scheme. Do you do one row ,and then mask for the next row and so on?
Old 05-14-2014, 06:04 AM
Capflyer's Avatar
Capflyer Capflyer is offline
5" in a diamond pattern.
Mike
RV4/HRII Hybrid - Building
RV8 Hot Rod "Drone Killer" - Flying
RV8 Blue Nose "Look'n Good" - Flying
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 05-14-2014, 06:13 AM
Tony Spicer Tony Spicer is offline
Here's what 3" looks like:
https://picasaweb.google.com/tonyboy...87273401514514
And if you do the rudder you might as well do the other end:
https://picasaweb.google.com/tonyboy...15579909417090
Tony
Old 05-14-2014, 07:14 AM
Mine is being finished at this time. The checkers are 2", rudder only and with pointy edge up so it will look like diamonds. The guy doing it has done many such designs on race cars. Will post a picture when I pick it up next Monday.
All the other parts - ailerons, flaps, HS, VS, canopy, cowl, wing tips, fairings, wing and fuselage bottom are painted. Reassembling the beast at present, will re-weigh it, and get on with flying - finally.
Serious polishing of what has not been painted will follow on rainy days.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 05-14-2014, 07:41 AM
Default Thanks Everybody
I think the 3" block is what I am leaning towards, thanks for the input
Old 05-14-2014, 07:42 AM
brooksrv6 brooksrv6 is offline
I did mine in 3". Went to a local sign shop that cuts vinyl and had them cut me 2 "spray mask" of 3" squares. Painted rudder white, applied mask and shot black, removed mask and cleared.
Chris
