Old 03-30-2014, 10:49 AM
jmcanty3's Avatar
jmcanty3 jmcanty3 is offline
Question Dimpled where I shouldn't
I went into the workshop this weekend with a great attitude to "get this tail done." While cruising along dimpling my ribs, I failed to recognize that the ends are fastened with 470s (rookie!), and I dimpled them as if though they were flush.
I decided to give the flush set in the squeezer a shot to flatten them out. I'm concerned that the material has been weakened and wont support the AN470s. I plan on calling Van's tomorrow to confirm my suspicion, but I figured I would see if anyone else has any input before stamping these ribs as scrap.
These are my VS-707 rib where it attaches the VS-702 front spar:
The inside flange:
John Canty
RV - 6 (SOLD)
Old 03-30-2014, 11:44 AM
DaleB's Avatar
DaleB DaleB is offline
Looks to me like it needs more of a squeeze with the flush set. I (and many others) have done this before -- dimpling holes that should not be dimpled, and even dimpling the wrong way. When I asked Van's they told me I could flatten it back out once. Repeated dimpling and flattening would weaken the metal too much. Wouldn't hurt to call or email them and confirm, though.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 03-30-2014, 09:11 PM
Jimboscr's Avatar
Jimboscr Jimboscr is offline
Default As above
Yep, get out the flat dies and squeeze them back flat.
Old 03-31-2014, 04:20 PM
mvidalr's Avatar
mvidalr mvidalr is offline
I did the same with one rib in the Fuel Tank. After posting my question here:
http://www.vansairforce.com/communit...d.php?t=110927
I decided the tank area is critical to high loads imposed by the wings and the fuel itself, so it would be wise to replace the rib with a new one. $20+ Dollars is not too much to pay for peace of mind.
You will find many different opinions here. Some based on common sense and some based on experience, all of them valid to a certain level, but none as important, or final as from Van's itself.
Good luck!
Miguel Vidal
EAA #1133587
RV-8 SB Wings in Monterrey, Mexico
N511MV Registered
MyKitLog
Old 03-31-2014, 11:29 PM
jmcanty3's Avatar
Default New order
I'm ordering new ribs. It's cheap and easy.
Vans did suggest that a doubler would do the trick (scrap piece behind flange that would sandwhich the compromised dimples). I'm sure the fix would be acceptable, but I'd rather build as the plans intend...
Initially, I was concerned that I would screw up the match drilled skins by replacing the ribs. Turns out that's not an issue in this case, which made the decision to replace simple.
Learning a lot!
Thanks for the suggestions guys.
John
John Canty
RV - 6 (SOLD)
Old 03-31-2014, 11:33 PM
billytime1 billytime1 is offline
Default billytime
I would buy new ribs and embrace the journey. I have made 3 boneheads on my rv7 tail and have set 6 rivets. You will get in the groove after a while and feel amazed at how you learn from your mistake and remember this always... This race goes to the tortoise not the hare
