Old 03-25-2014, 08:59 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default everyone should smoke!
Smoke -ON-
click on the image
4-pipe exhaust with injectors in 3 and 4.
I have a bit of a pieced together system... an old tank and pump from Smokingplanes, smoke injectors and a needle valve from Smoke System Helper, hose from NAPA, fittings and such from ACS, SS lines from VANS, and most excellent quick Jiffy-tite disconnect push lock fittings from JEGS...
here is the basic layout in the baggage compartment:
after testing the setup I removed the baggage pan to layout structural support:
back together:
here are the injectors:
Fun
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,535 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 03-26-2014, 09:40 AM
Marc DeGirolamo's Avatar
Marc DeGirolamo Marc DeGirolamo is offline
Default Oil and oxygen
Stephen,
Nice smoke generation. I noticed your set up and that you have the Oxygen bottle really close to the oil tank......not a good scenario if you have a leak, fire etc. ?? Nice looking clean installation.
Marc
Marc DeGirolamo
Canadian..Rv-4 Flying
VAF # 144
Last edited by Marc DeGirolamo : 03-26-2014 at 04:53 PM. Reason: Wrong name, added comment
Old 03-26-2014, 08:19 PM
Smilin' Jack Smilin' Jack is offline
Stephen,
Great installation. Marvin is a great fellow to work with and has a lot of expertise on these systems.
I too have mine plumbed into the 3 and 4 exhaust system on my 4 pipe Vetterman exhaust. It works fine.
See ya at Oshkosh. I hope.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
