Go Back   VAF Forums > Model Specific > RV-9/9A
Old 03-16-2014, 06:58 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default What do I do next? I'm stuck :(
I want to get back / finish my 9A project but I'm kind of stuck. All of the major construction is done. The pictures tell the story:
Wings and tail have been attached, controls rigged.
Fuselage, canopy and all structure done and on its gear.
Finished all of the tip ribs - at least as far as I'm going to before paint prep:
Wing tips installed with hinge:
All avionics and wiring installed and tested:
I'm trying to figure out what to do next. I have a partially overhauled O-320. It has been disassembled and case, crank, cam, steel gears, lifters, etc have been overhauled. To finish it I'd need to buy bearings, gaskets, oil pump, vernatherm, and 4 cylinders. Plus ignition, fuel, and exhaust system. I also have a prop and spinner.
If all of that is too expen$ive to do now, is there something else I could do? I thought of just loosely assembling the bottom end, even with the old bearings, to allow me to move forward on the cowl. Is it worth it? Or would I pretty much need a fuel servo or carb soon?
I also thought that I could work on the gear fairings (but I hate fiberglass and aren't too excited about it).
Any advice would be appreciated.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 03-16-2014, 07:05 PM
boom3's Avatar
boom3 boom3 is offline
You could jack it up, level it, and start working on your wheel pants. Not particularly fun but you won't feel rushed like you might later. They'll keep you busy for awhile.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 03-16-2014, 07:10 PM
g zero g zero is offline
Default What to do
For starters you could remove the blue plastic ..... I would get the engine hung as you suggested and work on the cowl . Finish all your fiberglass including wheel pants . No sense moving to a hangar when you can keep it at home for free until you get the engine ,prop , baffles finished .
Can you paint ? I am painting mine now , before first flight . Might consider the cost savings of doing it yourself , lots of labor with minimal material cost ( in airplane $$ )
Tom
Rv8
N 666 TA
First Flight 2-3-2015 🚀
Old 03-16-2014, 07:14 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Dave... beautiful craftsmanship on the plane and an awesome dog!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-16-2014, 07:22 PM
rzbill's Avatar
rzbill rzbill is offline
+1 for wheel pants and gear legs. Takes more time than you think, and you can be one of the few that can put them all on immediately after you are satisfied with wheels/brakes in Phase 1 rather than having to build them when you would rather fly. There are plently of old RVs that still don't have intersection fairings on them.
Bill Pendergrass
ME/AE '82
Old 03-16-2014, 07:32 PM
I was not going to say fiberglass, but it looks like it is in your very near future.
Reiley
VAF# 671
Friend of the RV-1
Old 03-17-2014, 07:42 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Cowl
Assemble the case and crank and do the cowl.
With out the calendars you will have an easer time drilling the side hinges.
Then do wheel pants and farrings.
You will have the thing finished except the engine over haul.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 03-17-2014, 08:26 AM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
Yours looks exactly like my 7A. However I am one step ahead in that I just finished my pants and fairings. Took about 4 weeks to get to the final "ready for paint" stage. And you are right that it is a painful task, but when its done, you will be happy that you won't have to do it when you a close to, or after, first flight. I plan to have mine painted before I fly it so it had to be done anyway.
My next step is engine, spinner, cowl, and baffles. Then to the paint shop and final assembly.
I delayed the engine till last because the plane becomes too long to fit in the garage unless I turn it on an angle. That means my wifes car now gets to stay outside for a while. She is not happy about that, but I tried to minimize the time she had to deal with it.
Good Luck. Almost there!
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 03-17-2014, 09:12 AM
Don Jones's Avatar
Don Jones Don Jones is offline
I did exactly as Jay suggested. I built the engine less cylinders since I was
waiting on the $ to buy them. Did the cowl and lots of the basic wiring and plumbing to the engine. Made the cowl much easier.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 03-17-2014, 09:23 AM
mikehoover's Avatar
mikehoover mikehoover is offline
+4 for gear leg fairing and wheel pants. Much easier to do now with the wings off.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
