w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 01-31-2014, 09:27 PM
RV7A Flyer's Avatar
Default SB 14-01-31; RV-6, 7, 8
A new service bulletin came out today for cracks in the HS forward spar:
http://www.vansaircraft.com/pdf/sb014-01-31.pdf
Old 01-31-2014, 10:01 PM
It doesn't say for the 9 models, but I am reading this pretty close and will see if it is looks like it may apply.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
2023
Old 01-31-2014, 10:07 PM
hydroguy2's Avatar
nine's have a different HS.
I just inspected my tail group last month...didn't see anything, but wonder if I gave it a close enough look.
Old 01-31-2014, 10:13 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Clearly this is a -6, -7, -8 thing. And wow...
kevinh's Avatar
kevinh kevinh is offline
To do the mod looks painful but not horrible - mostly just the limited access for drilling out some of the rivets...
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 01-31-2014, 10:28 PM
jay.pearlman jay.pearlman is offline
It would be good to know how many of these cracks have occurred out of the many RV6,7,8 flying. Can we report in this thread the results of inspections as they occur?
Old 01-31-2014, 10:37 PM
Arie's Avatar
Arie Arie is offline
Default New SB
Wow. This SB is not a quick weekend afternoon fix, this seems to be a major deconstruction ,and then try to but it all back together again with very limited access to buck rivets. When I made my relieve notches in the front spar for the bend I made 100% sure that it was completly deburred and rounded at all corners to prevent cracks, just in this area. I am sure that my relieve notches are as smooth as it can be. Do I understand that this SB must be complied with even if there is no cracks, or is this a fix if a crack is detected. Maybe Alan from antisplat can produce a better way of doing this, like his fix for preventing cracks in the vertical stab front spar...
I can just see that to try and remove those rivets will leave a lot of folks with enlarged holes and a messed up HS that will be worse than before the fix.
Old 01-31-2014, 10:45 PM
kevinh's Avatar
From reading the SB, inspecting before further flight and then every annual seems fine. So if you don't have cracks and don't think you'll get them just doing that until a crack (possibly) shows up some year seems like a fine way to go...
Old 01-31-2014, 11:07 PM
eddieseve eddieseve is offline
I'll be inspecting my RV7 tomorrow morning, will post results
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 02-01-2014, 01:19 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Does anybody know of occurrences of this cracking i.e. who / what / why / when triggered this SB? I have one possible suspicion...
Andy
