Old 01-02-2014, 11:26 AM
10 G 10 G is offline
Default ULPower for RV-3
Hello fellow aviators,
I hope I will be building an RV soon, I am closely watching UL power engines .... I think that UL 390 would fit an rv 3 perfectly.... with 220 lbs installed weight, it would make an lightweight, nimble but powerful rv3.
Are there any RV3 with ULPower engine or maybe with Jab3300?
Old 01-02-2014, 11:29 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Robert, welcome to the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-02-2014, 11:43 AM
ppilotmike's Avatar
Default Interesting idea.
Seems like a neat idea, but consider that most RV3s have issues with aft CG, so the weight reduction up front might require serious mount/cowl modifications to get the weight forward enough to counteract this. I'm not even near ready to install an engine in my 3 build, but I am watching the development of these new engines...
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 01-02-2014, 12:08 PM
Thanks for the welcome
Installed weight should be more or less the same as with continental O200, and if I am correct old RV3 plans have O 200 option, so it would need an coustom engine mount, but I think this should not be a big deal.
I am more worried about ethanol... If I am remember correctly german OMW web site advise against storing ethanol mixed fuel in alu containers... so there may be an issue with fuel tanks?
