Here is my 2 cents worth.
After searching the forum on how to roll the leading edges on the elevators and rudder and finding a lot of useful info I thought I might publish my method.
I decided to go with 2 techniques I found here. One is clamping down the pipe with wooden blocks and the other is using a plastic sheet under your work to allow the part to slide while rolling. After finding varying thicknesses of pipe or broomstick here I decided to use the closest I could find to the recommended vans thickness of one half inch, in my case 3/5 inch conduit.
While looking through my shop to find something to use as a t-bar I ran into these. Pipe wrenches.
How easy is that. Stuck one of these in the end of the pipe and turned it with a socket wrench to bend the ends up just past 45 degrees. I started to bend the sections separately on the one side but seeing as though it went so smooth I decided to bend all three at once on the other side. That worked just fine.
Hope it helps..
Hope it helps..
