Old 11-24-2013, 07:14 AM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Default Gear brake assembly
Hi Guys,
I have finished the first part of the gear/brake assembly (left gear shown below). My question is whether the brake mounting plate is on right. I couldn't tell by the drawings which way it went on. From the pictures I seen from other builders websites, it looked like this was the correct setup. What do you think? Thanks in advance!
Smitty
Old 11-25-2013, 10:10 AM
bruceh's Avatar
bruceh bruceh is offline
Looks good. Eventually you will get to this:
I had to shim out the bracket on one side with some thin washers to give the required 1/16" clearance to the brake disc.
Bruce Hill
2020 VAF donator
Old 11-25-2013, 06:06 PM
Mark C. Mark C. is offline
Thanks Bruce, I to used your picutures for help and orientation. The Vans prints were confusing to me.. Mark C. RV9A
Old 11-26-2013, 04:06 AM
SmittysRV's Avatar
Thanks Bruce!
Smitty
