Old 11-20-2013, 09:13 AM
jsenft jsenft is offline
Default Frosted Windshield
Sorry, not really an RV-12 specific question. After my plane has sits overnight I get frost on the windshield. Currently, I start the engine and turn the plane into the sun to melt the frost burning fuel. Can anyone recommend a spray that I can use to defrost the windshield without damage?
P.S. Move to Florida is not an option for my wife.
Old 11-20-2013, 09:25 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Strange. I don't seem to ever have that problem
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
RV12 built and flying
Old 11-20-2013, 10:20 AM
N941WR's Avatar
N941WR N941WR is offline
Default An ounce of prevention?
Can you use a lightweight canopy cover when parking overnight? That doesn't do much for the frost on the wings but it will definitely keep the frost off the canopy.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-20-2013, 03:06 PM
Beancounter Beancounter is offline
Default Frost
I use automotive windshield washer fluid in a garden sprayer on the wings my 9. Some formulations work much better than others which may have to do with the alcohol concentration. I don't know what the RV12 windscreen is made of, so use with caution.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 11-20-2013, 11:12 PM
Wayne Gillispie Wayne Gillispie is offline
I use 91% isopropyl alcohol in a 1 qt spray bottle. Take precautions as it is a fire hazard. Search Amazon if you need gallons or higher concentration. Ethyl alcohol appears to be less harsh on plexiglass and can be easily obtained.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 11-21-2013, 04:43 AM
kiwipete kiwipete is offline
Default Wings?
If there's Frost on the windscreen please make sure there's non on the wings and tail as well. I've seen the results of people trying to takeoff with frost on the wings and it wasn't pretty!
Peter
RV7 G-PBEC Flying
RV10 Finishing
Old 11-21-2013, 06:07 AM
N941WR's Avatar
I was under the impression that alcohol will cause crazing on the canopy over time. Is this not true?
Bill R.
SC86 - Easley, SC
Old 11-21-2013, 06:52 AM
terrykohler terrykohler is offline
Default I Try to Stay Away From Anything That "Might"...
http://www.eplastics.com/Plastic/Pla...iglass-Acrylic
Terry, CFI
RV9A N323TP
Old 11-21-2013, 06:57 AM
MarkW's Avatar
MarkW MarkW is offline
Bill,
Since you asked.
I had **** on my canopy from lack of protection during construction. I looked for a solvent that would handle the mess without damage. I was told MEK would work but before using I checked it out. I found a great website that shows Plexiglass chemical compatability.
I used MEK anyway and found only slight reaction. I was able to polish out the haziness with Novus.
Short periods of Alcohol use look OK in cooler conditions but the RV-12 does not use Plexiglass so beware.
As Bill originally mentioned, keeping the moisture off before it turns to frost would be the best bet.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 11-21-2013, 07:31 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
You might try propylene glycol aka "pink stuff" or otherwise known as aircraft deicing fluid. Go to Walmart and pick up a gallon of boat or Rv antifreeze...not auto coolant (ethylene glycol), but propylene glycol. It's non toxic. Spray it on the windshield and see if that helps.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
