Old 01-20-2022, 07:55 AM
ctremie ctremie is offline
Default Concerned about under dimpling, Please let me know your thoughts
I have a DRDT-2 , with dimple dies from ISham (Planetools.com), I have the drdt-2 setup to flex about 1/8th of an inch at the bottom of the stroke. But I am concerned about the dimples looking under dimpled. Thoughts?
Different dies maybe>?
Click image for larger version
ID:	21214  Click image for larger version
ID:	21215  Click image for larger version
ID:	21216  Click image for larger version
Old 01-20-2022, 08:06 AM
rvbuilder2002's Avatar
I most definitely see under formed dimples.
It could be caused by the dimple dies, but in my opinion, the DRDT-2 is always going to produce dimples of lesser quality than other methods.
Scott McDaniels
Hubbard, Oregon
Van's Aircraft Engineering Prototype Shop
FAA/DAR
Old 01-20-2022, 08:17 AM
Nova RV Nova RV is offline
Just need more pressure on the DRDT. Get some scrap alum and make practice dimples in it and adjust until there is no dishing around the dimple.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 01-20-2022, 08:22 AM
The edges where done with Rivet Squeezer. What method do you like best?
Old 01-20-2022, 08:23 AM
Thanks Chris will try
Old 01-20-2022, 08:41 AM
Straight on they look good but when you get a distance away they seem to distort, is this normal
ID:	21218  Click image for larger version
ID:	21219  Click image for larger version
ID:	21220  Click image for larger version
wirejock's Avatar
wirejock wirejock is offline
Default Dimples
The dimples near your hand look better but still under. The ones at the top are very under dimpled.
I see no burnish marks. You may want to try some Cleveland dies.
I prefer a C-frame.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 01-20-2022, 08:58 AM
Bavafa Bavafa is offline
They are certainly under dimpled or not nearly as crisp of a dimple as they should be and I am with Scott 100%
You seem to be at the early stage of your build so still ways to go. It would be worthwhile to spend the $$ and time on a good dimpler and a good table/platform for it.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Old 01-20-2022, 09:00 AM
Pdp7427 Pdp7427 is offline
I’m FAR from any kind of expert. How do your dimples compare to the examples in the standard aircraft handbook or in the FAA Inspection and Repair Alterations book? I’m trying to reconcile why all of the books seem to prefer a dimple that only just accepts a flush rivet flush to skin while the forums always seem to prefer a deep dimple…?
Trying to learn myself.
Old 01-20-2022, 09:07 AM
So is the DRDT-2 and Isham Dimple dies not good? I also have it mounted on EAA workbench. What is your recommendations
Chad Tremie
RV-10 #42420 (Emp kit building)
