Keep VAF
Going
01-16-2022, 05:59 PM
Help with Oil Cooler Selection for RV8 w/ Angle Valve IO-360
I am needing to change out oil cooler on my RV8 and trying to see what the best option is. I am in Texas so optimum cooling is important. I was running a PosiTech 4215 mounted to baffling behind #4 before it broke a flange. Searched through the VAF archives on this first but most of the threads I found were pre 2010 and many of these coolers like PosiTech and Harrison are no longer around.
I was looking at the Aero Classics HE Series Part #8001599 (8 row 6" long core) this is an $875 unit. From my understanding this is a former Stewart Warner unit that is now Aero Classics.
There was also an Aero Classics Remote Mount 9 Row Part #8000074 for around $390.
Both of these look very similar. From all I can tell the HE series is a "Bar & Plate" design and the Remote Mount is a "Drawn Cup". Not exactly sure of the difference and if one is much more superior to the other.
Does anyone have any experience in using either of these in a hot climate and have any recommendations for io-360 angle valve?
N78DL
RV8 at 52F
01-16-2022, 06:15 PM
Just bought mine from Pacific Oil Coolers. #8001599, For a parallel valve. Give them a call. Wayne explained everything in detail. He’ll get you set up. The HE line are most like the original Stewart Warner. Higher quality, better fin material.
PA-22-135
RV-8A Project
2022 Dues Paid
01-16-2022, 06:38 PM
Airflow X Series 2006X
Best cooler I've found yet.
https://www.aircraftspruce.com/catal...sOilCooler.php
PN: 08-06154
Nick "Rehab" Nafsinger
91TS Rosharon, TX
Current project: Glasair 1RG. IO-360, SDS EFI, WW RV74, G3X Touch.
RV-8 after the Glasair, I promise. 🫣
RV-4 Bought 2019. SDS EFI IO-360, Hartzell CS, DanH inspired custom intake, G3x Panel .... Sold. 2022
RV-8 SB, "Back burner project."
RV-10 Built 2010, Sold 2019
01-16-2022, 07:10 PM
Wayne knows oil coolers. Bought mine from him (Pacific Oil Cooler) years ago. 9 row, 8001689. Firewall mounted using the RV10 mount. Rare to see my oil temp exceed 190. And only if extended climb midsummer.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
900+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019 & 2021
01-16-2022, 07:40 PM
Just for ref this is the one I use for HC 370 with piston squirters, works great but mounted on the firewall now.
Aero Classis HE
10611R 8001649 11 ROW 6" LONG CORE, 08-07432
$875.00
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
01-16-2022, 08:11 PM
Originally Posted by Nick
I'll second this. I used a Showplanes style mount.
https://showplanes.com/ecom-prodshow/OCM-8.html
Wayne at Aero Classics was great on a bigger cooler for my Cardinal, and he sent me a bunch of options for my RV8. However the 2006x is a monster. I wanted the biggest baddest cooler I could find, and 2 years ago this was it.
01-17-2022, 12:03 AM
This is essentially the same cooler that Vans sells for the RV-10 and the angle-valve engines. I made a firewall mount similar to the RV-10 mount but with the angle adjusted to align with the engine mount tubes.
Be sure to supply it with plenty of air. 4" Scat tubing, and a good diffuser transition from the 4" duct to the cooler box.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
01-17-2022, 12:11 AM
I did an IO-540 cooler on firewall...emphasis firewall...it's too big for mounting on the back side of the cylinder. That said put a 30 degree down extension on exit ramp from cowling. That exit ramp/cowl flap did the trick. And My bird flies at high density altitude. Good luck.
01-17-2022, 02:19 PM
My advice.... stay with a Stewart Warner clone available from Pacific Oil Cooler, you will write one check, and never worry again about Oil temps! The SW is about 30% more efficient than most of the "others".
DAR Gary
01-17-2022, 02:32 PM
How do u drain it ??
This is how I drain the extra quart of dirty oil from mine :
Keith
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
