Crowfoot Wrench Storage
rv12is
Active Member
I've been storing my crowfoot wrench set on the storage rail that it came with. This works, but I wanted a more compact solution. Here is what I came up with.
It takes up quite a bit less room in my tool drawer, the sizes are clearly marked, and they can't be put back in place out of order.
Here's a link to the design:https://www.printables.com/model/361360-crowfoot-10-pc-wrench-holder. It's customized for my specific set (Craftsman CMMT12052LZ 10 pc. SAE Crowfoot wrench set) so I don't know how useful this specific design will be for others. But the concept could be easily adapted for other sets.
I like it...thanks for posting the link. Any chance you could post the Solidworks file? Would like to edit for my metric set as well.
Nice!
Thanks. I hadn't printed anything in a while and this worked great.
Not meaning to hijack the thread, but Snap-On makes great crowfoot holders. Part number A277 at $7.95 each. Just throw them in a drawer, can pull apart to remove one tool while still keeping all the unused ones on each half.
GM
Nice!
Unfortunately, no. The design was done in Fusion 360, and I don't know a good way to convert between the two.
The only way i've found is to export STEP or IGES (forget which one but I seem to recall F360 can do one of those) and then import to SW.
