w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 03-15-2023, 09:33 PM
Frac0220's Avatar
Frac0220 Frac0220 is offline
Default Conditional Inspection Shop Recommendations Southeast
Hello!
First time poster here. Please move the thread if not allowed.
We recently acquired a 2019 RV-12iS SLSA S/N 12078 and we are based out of KLZU. We are having an absolute blast flying the aircraft and just planning ahead.
Our condition inspection is due in June and we are looking to get on a shop or A/P's schedule to get it done.
I reached out to Vic at Base Leg Aviation in FFC and he said they are currently not doing any mx. I also reached out to Hawk Aviation and I think they may have gone out of business.
I wanted to reach out to this amazing group and see if they had any recommendations for the GA, TN, SC, NC, or AL area. Very appreciative for any guidance!
Brian
2019 RV-12iS SLSA
Old 03-16-2023, 04:41 AM
thiggins thiggins is offline
Try contacting Synergy in Newnan.
https://synergyair.com/
Donation 2023 paid
ASEL INST COMM Tail-wheeler
RV-12iS builder (Empennage complete, Wings complete!, Fuselage well under way!, finish kit under way!, Garmin avionics under way!, engine ordered, shop out of order )
Got a hangar, and moved some large pieces in!
https://eaabuilderslog.org/?blproject&proj=7buPHH99v
Old 03-16-2023, 09:21 AM
larrynew's Avatar
larrynew larrynew is offline
Here’s a map of Light Sport Repairmen with the Maintenance rating that can do annual condition inspections and 100 hr inspections on an SLSA.
https://rainbowaviation.com/?page_id=4854
Larry New
RV-7A - Built, flew 1000 hrs, 48 States in 7 Days, sold
RV-10 - Built, flying 500+ hrs
RV-Pedal Plane - Built, grandkids flying
RV-12iS - Building, empennage
VAF on Annual Autopay
Old 03-16-2023, 11:14 AM
KatanaPilot's Avatar
KatanaPilot KatanaPilot is offline
+1 on Synergy Air South.
Just an interesting note - the Manager/Lead Technician - Allen Nelson, helped build most of the S-LSA RV-12’s that were done by Synergy Air (Eugene) under contract with Van’s.
Be advised, they are very busy at SAS.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021) - now at her new home in Lakeville, MN
RV-10ER officially an airplane as of 4/5/22! Headed to Evoke 7/17/23
EAA Technical Counselor
Old 03-16-2023, 11:17 AM
Dugaru's Avatar
Dugaru Dugaru is offline
Default NC
Very happy with Sanders Aviation in Edenton NC. He works on a fair number of RVs, including mine.
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2023 Dues Paid
Old 03-16-2023, 11:44 AM
rolivi's Avatar
rolivi rolivi is offline
You've got 3.5 months. Have you thought about doing the 15day course to be LSRM? With that you can sign off all the LSA's you want?
My case, I'm a non-builder with E-AB. I use a "regular A&P" for most everything. He knows my Lycosaurus plenty well.
Consider widening your net to look for A&P's that are strong with Rotax. The other systems are not complicated, and metal planes show their stress the same, certificated or not.
Rob
RV-6A (Purchased)
2023 Dues Paid
Old 03-16-2023, 11:46 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I have seen, and am still dealing with, RV-12 built by Synergy in Eugene, OR. Extremely poor craftsmanship. You can search my previous posts...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 850
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 03-16-2023, 03:10 PM
But yet you’ve put 800 or so hours on it? Guess it can’t be too bad. And it passed Van’s QC as well…
Krea Ellis
Locust Grove, GA
Old 03-16-2023, 04:12 PM
Piper J3's Avatar
You should search my posts before making rosy assumption. My plane has 800TT and friend's synergy-built about half that.... Van's took assembly of S-SLA RV-12's in-house. I think based partially on some negative feedback. The major problems, such as prop bolts not torqued and prop hub destroyed, were escalated to Van's...
Old 03-16-2023, 06:10 PM
jrtens's Avatar
jrtens jrtens is offline
Brian
Welcome to VAF Brian!
You have the 4th RV-12iS off the line in Aurora.
You may want to consider getting on the schedule at Lockwood in Sebring just in case you can’t find something closer by June. Good luck with your bird. I have 12079.
Jon
2019 12iS SLSA
KAWO
