w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-07-2023, 04:40 PM
HEB1022 HEB1022 is offline
Default RV-12is Stall Indicator
Fellow RV12 pilots. I am looking for some guidance on something I observed today during pattern work. I was getting pretty frequent stall warning (audible and dynon console light) during downwind, base, and final, although my IAS were within normal ranges. I have not seen this before and when looking at my dynon user data downloads, prior to today, the stall warning rarely went off except in final flair, but today it was activating pretty frequently. The stall warning vane on the wing does not appear to my untrained eye as bent or bounded up. Any ideas on steps to track down what is going on?
Thanks in advance,
Harry
Old 05-07-2023, 04:55 PM
Bob Y Bob Y is offline
Happen to me occasionally too, in the pattern particularly, when the winds are high.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
#121047
Old 05-08-2023, 08:32 AM
DHeal DHeal is offline
Adjust the stall warning vane per Page F-04 of the PAP:
https://www.vansaircraft.com/wp-cont...edures-R14.pdf
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since Feb 2014 - 1,290+ hours (as of May 2023)!
VAF donation through June 2023.
Old 05-08-2023, 01:45 PM
Thanks David, I will take a look at that. Is this something that should fall out of adjustment, once set? This issue just came up suddenly
Thanks...
Old 05-08-2023, 03:11 PM
If the stall warning vane attachment/adjustment screws loosened, the vane could move out of adjustment. More likely is that someone inadvertently bumped into it while admiring your plane -- you can usually identify the culprit by the blood gushing from his/her thigh. That is why whenever I park my RV-12 I put a warning cover on the pitot tube and stall warning vane.
Old 05-08-2023, 08:42 PM
blaplante blaplante is offline
Default On the Other Hand!
Our flying club got a new (to the club) Piper Cherokee. Similar stuff, stall warning (light) going off on departures etc. Odd.
Turned out the plane had a static system leak. The stall light was correct... the airspeed indications were wrong.
RV6A in phase 2 as of April 2016
Donation made Dec 2022
