Old 02-16-2021, 09:40 PM
PhatRV PhatRV is offline
Default How Know Which Mag Wire Connect To Which Cylinder
I have a Slick magneto with impulse coupler on the left side of the engine. How can I know which wire goes to which cylinder? From what I can find this is what I "think" the sparkplug wiring should be. However, is there a way to find out with certainty which wire goes to which cylinder from looking at the magneto?
I've search the Champion website and could not find the documentation other than the sales brochures. The picture is from Lycoming M1A engine. However, various Lycoming docs only show a doodle of the wiring but do not explain how to know which wire goes where.
Thanks in advance.
Click image for larger version
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Prep for cowl install
Electrical -- 90%
Donation paid through 2021
Old 02-16-2021, 11:01 PM
vlittle's Avatar
vlittle vlittle is offline
The cylinder number is stamped on the spark plug nut at the end of the wires.
V e r n. ====
RV-9A complete
Harmon Rocket complete
Member of OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 02-16-2021, 11:37 PM
+1. On standard harnesses the cylinder/plug is stamped on the nut.
Starting at your red ‘1’ and moving to lower right (counterclockwise) the order is 1T - 3T - 2B - 4B where the T is top and the B is bottom plug.
For the other mag start at upper right, move counterclockwise, order is 1B-3B-2T-4T.
Be sure to check the timing prior to engine start.
Old 02-17-2021, 10:07 AM
Raymo's Avatar
Raymo Raymo is offline
This link will take you to a PDF for Lycoming engines.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-17-2021, 01:58 PM
Thanks for the replies. I have to check the nut again, maybe it was the low light in the garage at night that I missed these details. Regarding the Lycoming manual, I have the same PDF files but they don't show the wiring number in the illustration.
Wing -- Closed
Electrical -- 90%
Old 02-17-2021, 02:07 PM
You just have to find the right manual. I found it online.
Old 02-17-2021, 02:25 PM
Avanza Avanza is offline
Smile Firing order
https://www.superiorairparts.com/fil...42/SVIOM01.pdf
look at page 42, itīs a good picture.
good luck.
Old 02-17-2021, 02:26 PM
Smile Firing order
good luck.
