When you order make sure of the brackets that you are using. I have the aftermarket brackets which are 3/8" inside dimension. The standard ends for the easy lift struts are 8mm which are just a little too thick to fit. You can specify the E2M8 hinge ends, which are 5mm thick, and will allow the use of a couple of washers to shim them.
These struts work great!
