I'll add this to the mix....just posted on our Ohio Valley RVators site this morning:
My new long legged RV4 has had a bit of gear leg shimmy that can be
felt inside when taxiing and on take off roll and on landing. Shiner
called yesterday and said that it was REALLY shaking when we did a 3
ship take off last weekend. I'm glad he took the time to mention this
cause I was wondering what it looked like from outside the plane. He
said that the pants looked like they were going to shake off the plane.
The previous owner said that the shaking started when he put
some 'gooey flat fix' in the tires to help hold the air pressure. He
was going to replace the tubes but never got around to it. After
talking to Shiner I decided to change out the tubes NOW rather than
wait till the tires wore out (they're at about 80%). So, I went to the
airport last night and replaced both tubes with the new 'leak stop'
tubes that came with the plane. I even checked the brakes and repacked
the inner and outer bearings on each wheel while it was apart. I then
did taxi tests from 5mph to about 25mph and NO SHAKE. That said.....I
turned on all the lights and did my 3 stop and goes for night flying
currency and, again....NO SHAKE could be felt in the cabin at all. Nice
and smooth the whole time.....hopefully it 'looks' nice and smooth on
the outside as well.
Oh yea.....if you shake the old tubes.....you can feel and hear the
liquid inside of them......kind of like shaking a milk jug with about a
pint of milk in the bottom!!
Be sure to buy the 'leak guard' tubes and don't use flat fix in your tubes!!
Rick in Ohio at the Buffalo Farm - loosing count of RV/Rocket projects
http://rv6rick.tripod.com/ohiovalleyrvators/
