Photoadjuster,
I have a McCauley prop from a Mooney 201 on my RV6, that now has a total of 46 hrs on it (just got my RV6 flying in July of '04). This prop is the one that has the 2 large paddle looking type blades on it, and appears to be working quite well on my 0-360 powered RV6. The original diameter is 74" as used on the Mooney, but mine has been cut down to 72" diameter (73" is all that is legal to cut it down to for use on a certified Mooney, so when I found one that had been in a ground strike while taxiing I was able to get mine for an extremely low cost because it had already been cut to the minimum and couldn't be repaired without being cut down below that size ($1200 originally with an $800 rebuild cost back about 6 years ago). I turn it up to 2850 RPM on takeoff and am getting about 3000 ft/min climb rate, which is very good for an 0-360 powered RV6. At 8000 ft it cruises at 212 mph (GPS ground speed) at 23" MAP & 2300 RPM. It would appear that I have maxed out the prop pitch at that speed, because I can't get any lower than 2300 RPM at max throttle at that altitude. My prop shop says that there is a small ring spacer that they can remove that will allow me to get about 2-3 degrees more pitch if I want it, which would enable me to pull the RPM down lower to around 2200 RPM & 23" MAP so that I can maximize my fuel economy. I'm sure the cruise speed will drop slightly, but so will my fuel consumption (I figure I can still get at least 205-208 mph with a fuel burn of only 8.5 GPH netting slightly better than 24 mpg at that speed...pretty respectable for an RV6 to be sure!!).
While you are correct that the McCauley props seem to be resistant to AD's unlike the Hartzell's (this is due in part to the much more massive bearing size that the McCauley hub has and the fact that is is manufactured as a one piece hub), there are however a few disadvantages in using it.
First of all is the fact that it is VERY difficult to get a spinner backplate to fit up to it. This is due to the hub having no provision to mount a backplate to it. The Hartzell prop is a split hub design, so it enables one to mount a backplate to the bolts that hold the hub together...not so for the McCauley. It requires a set of two plates to be attached to the hub via the hub mounting bolts (which are really studs that are screwed into castlelated nuts that are slid into cutouts machined into the side of the hub and that are threadlocked in order to create a bolt), and these two plates have six holes each in them (for a total of 12 holes) on a 6 5/8" bolt circle that the backplate has to attach to. Normally almost ALL McCauley props utilize a backplate that is mounted to the holes on the ring gear on Lycoming engine installations (which isn't possible to do on tightly cowled planes like the RV's), but there is one McCauley installation on a Cessna that uses the two plates that I mentioned above, so at least the plates are available from most prop shops. Still, there is NO available spinner backplate available from Van's, so you will have to make a custom one on your own out of carbon fiber. There is one other guy here in the US that did just that for an ACI installation in his RV8 (ACI uses the McCauley hub for their composite blade upgrade), and he made up a few extra backplates when he made his mould which turned out to work for me with some modification to the cowling on my RV6. If you go with a McCauley prop I recommend that you try to use the same backplate he makes (I can give you his name & number if you decide to go this route) since it will save you a ton of time & expense making your own mould. I also have an old style long RV6 cowling, so I had to have a 1 5/8" long custom prop spacer made to extend the McCauley hub out, but I still had to trim the face of the cowling back 1/4" to get a reasonable 1/4" gap between the back of the backplate (which I cut as short as possible) & the cowling. Unfortunately in order to get a backplate to work on any McCauley prop on a Lycoming engine you have to be able to pull it back up against the ring gear so that you can get a wrench on the prop bolts, and this means that the backplate can't be too long or you won't be able to get a wrench to fit in. This dictates that you either use a Mcauley extended hub design model 220(they are 6 1/2" long from hub mounting surface to blade centerline), or do like I did and make a custom spacer for use with the standard hub (such as is used on the Mooney prop that I have) that is 4 1/2" long. This also means that you can only make this setup work on a long type cowling, and NOT the shorter cowling that is all that Van's makes now. While the 2" shorter standard hub would seem to be a good fit with the shorter cowling, the backplate mounting plates will end up too close to the ring gear to allow the backplate to be slid back far enough to get access to the prop bolts with a wrench, so you won't be able to install the prop on the Lycoming engine. There is NO easy solution here that I can see other than the method I used. By the way, the aftermarket Sam James cowlings are longer just like Van's older long type cowling, so that is a good way to go if you want to use a McCauley prop, and want the supposed cooling drag reduction gain that they advertise (personally I doubt that they gain all that much to warrant the added cost they are, but then the quality of them is much better and may be the only choice for early RV6's that need a new cowling).
The second problem with alot of the McCauley props (and this includes my Mooney 201 version) is that it experiences a very rough reasonant vibration range that limits its use below 10" MAP when between 1500-1900 RPM which makes landing the RV6 tough without bringing it in with a bit of power, or at idle (keep in mind that all of these McCauley props MUST be used with a counterweighted Lycoming engine because of this). Pulling the engine back in that range is normally what most RV'ers do for an approach, but unfortuanately that only occurs below 10" of MAP when in minimum pitch so it makes landing kind of trickey (I am still trying to work out the best solution for landing approaches at this time). Even the Mooney's are placarded to avoid that range for operation, so it is obviously a function of the prop itself that is peculiar only to a McCauley.
I will say one thing though, the paddle bladed Mooney 201 McCauley prop sure looks MEAN on an RV6, and there is NO other prop that looks as good on the ground!!!!! Otherwise the McCauley props are great props, and FAR better & stronger than any of the Hartzell props (that is why ACI & Whirlwind uses the McCauley hub for their composite blade upgrades on aerobatic versions).
