Old 04-16-2021, 08:51 AM
huse0054 huse0054 is offline
Default Elevator aft stop
Does anyone have pictures of the elevator aft stop they have made to accommodate the service bulletin?
I need to remake mine as the elevator horn is a hitting too low on the angled cut off portion of the elevator horn. I am trying to get full 30 degrees of deflection which means I need to raise the stop up slightly.
Old 04-16-2021, 03:48 PM
Strikhedonia Strikhedonia is offline
Not a great photo but here is mine (under the angle aluminum is a solid aluminum bar, sorry I don't have the thickness.
https://photos.app.goo.gl/BzaHfAFxbYz66yGRA
www.strikhedonia.com
Chris French
RV10 flying
EAA #: 561223
Old 04-16-2021, 08:21 PM
Fantastic, thanks for the picture. That is helpful.
Old 04-16-2021, 09:26 PM
RandyAB RandyAB is offline
Section 5 has the exact numbers but if memory serves, I think 27deg up elevator is within the acceptable limit.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
