Go Back   VAF Forums > Main > Safety
Old 12-04-2020, 02:12 PM
KatieB's Avatar
KatieB KatieB is offline
Default NTSB recommends AD for certain oil filter adapters
I know most RV's use Lycomings or Lycoming clones, but I got this in my email and thought, just in case someone has a Continental with one of these F&M/Stratus oil filter adapters, it's good to know... Torn or unevenly compressed gaskets caused blowouts and loss of oil leading to 11 accidents identified by the NTSB.
https://www.ntsb.gov/news/press-rele...R20201203.aspx
Katie Bosman
CFII/A&P
EAA Homebuilt Advisory Council
Rebuilt most of SNF tornado victim RV-3B Tony Boy II (had to sell him, but he's flying!)
RV-9 93281 tail kit has arrived... here I go again!
VAF Dues Paid 2021!
Old 12-04-2020, 04:27 PM
Ralph Inkster Ralph Inkster is offline
Stratus site lists these for Continental 550 thru 300 & smaller engines.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 12-04-2020, 04:43 PM
Steve Melton's Avatar
that is probably the worst design I have ever seen
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 12-04-2020, 06:31 PM
1001001's Avatar
1001001 1001001 is offline
Thanks! I forwarded that over to the Mooneyspace forums since the M20K was called out specifically.
Old 12-04-2020, 06:37 PM
As a former 182/TCM O470 owner, I recall there was an AD quite a few years ago on the original TCM filter adaptor. (The jam nut could loosen, the adaptor would then rattle around and destroy the internal threads). It seems odd that a relatively simple part could cause so much trouble!
Old 12-05-2020, 08:02 PM
longranger's Avatar
There are many hundreds if not thousands of customers waiting on your better design, me included. Properly installed and torqued theyíre dry as a bone. If you torque it by the TFAR (that feels about right) method youíre going to have problems. You do have to be careful when removing and installing filters to prevent movement of the adapter relative to the accessory case. It that happens it WILL leak, and you WONíT stop it until you replace the gaskets/seals at both ends and properly retorque the assembly.
Miles (VAF# 1238, Paid up as of 12/20)
RV-7 TU 904KM (reserved)
Construction Log
Empennage Album, Wings Album, Fuselage Album
Old 12-05-2020, 09:20 PM
scsmith scsmith is offline
KatieB thanks for posting this. I have been thinking about putting one of these on our C-182B towplane. To Steve Melton's comment, it is true that what they had to work with is a pretty marginal sealing surface area, just asking to be disturbed. But, as longranger points out, it is about all that could be done with what they have to work with. I think with proper awareness and care, it can be adequately serviceable.
Not to start a Continental vs. Lycoming battle, (or maybe yeah, game on!) but the more I work with the O-470, the more I appreciate Lycoming's somewhat less primitive approach to many details.
Have you seen any timing marks on a Continental O-470?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 12-06-2020, 09:27 AM
FasGlas's Avatar
FasGlas FasGlas is offline
I've installed a few of these over the years and they can be a pain to get them to not leak and to stay tight.
Beech D17S Staggerwing
Lancair 360
Cessna 120
A&P IA
Old 12-06-2020, 09:40 AM
Still looking... to this point with my limited Continental experience, Iíve had to rely on the old piston stop/spinner dunce hat method.
Ralph
Old 12-06-2020, 05:07 PM
longranger's Avatar
Iíve not worked on an O-470, but my O-300 is of similar if not older vintage, and there are marks on the edge of the prop flange that you are somehow supposed to align with the case split several inches away. Fortunately I inherited my Dadís TimeRite...
Iím looking forward to what improvements a ďmodernĒ Lycoming whose basic design only dates back to the 1950s (as opposed to the 1930s and 40s) has to offer.
Construction Log
