Old 11-24-2020, 09:01 AM
bob888 bob888 is offline
Default Flaps zero vs reflex
Does anyone have data on performance differences between flaps zero and -3 degrees...esp takeoff performance? I can't subjectively appreciate any difference and it would be simpler to use just 3 flap settings...-3 deg, 15 deg, 30 deg and forget about 0 deg.
Old 11-24-2020, 11:58 AM
rdrcrmatt rdrcrmatt is offline
I get airborne earlier with flaps 0°.
Also, noticed even at low DA I lose 1-2 kts when I go flaps -3°
I need more testing.
Matt
CFI / RV-10
Old 11-24-2020, 02:27 PM
I get a slightly shorter ground roll at flaps zero (in trail). And, at sufficiently high density altitude, slightly faster cruise at flaps zero. I wouldn’t remove the option.
Old 11-25-2020, 09:10 AM
Deweyclawson Deweyclawson is offline
Default flaps 0
With 150 hrs in my RV10, I still don't understand the flaps.
1-2 kts faster with flaps 0
shorter ground roll flaps 0
What good is the -3 position?????
Dewey Clawson
Super Sabre Society
2012 RV10; 1947 Cessna 140, in progress
2021 dues exempt but paid anyhow
F100, A7D, A10, F16,
Fokker, Boeing, McDonnell-Douglas
Old 11-25-2020, 12:26 PM
Are you certain about this? I see a speed gain at flaps zero only with DA above 16000'. Lower, flaps -3 is faster.
Old 11-25-2020, 01:26 PM
lr172 lr172 is offline
I believe most of us see the same.
Old 11-25-2020, 06:07 PM
1001001's Avatar
1001001 1001001 is offline
Hey Dewey, maybe we should check your flap angles and see what they actually are; could the rigging be off?
Old 11-25-2020, 08:28 PM
scsmith scsmith is offline
It is interesting to read that there is some variation in builder experience with the cruise performance at different flap settings.
The RV-10 airfoil was designed to achieve a modest amount of laminar flow, and part of the expected benefit of the -3 flap setting at high IAS is that it increases the angle of attack a little to keep the airfoil well positioned in its modest laminar drag bucket.
If you have paint stripes along your leading edge, or less-smooth-than-average rivets on the wing forward of the spar - especially on the spanwise skin stiffeners, or anything else that might cause early transition, like just not washing the bugs off, then you may have early boundary layer transition and are not getting as much laminar flow - so you would not see the benefit of the reflexed flap setting (-3).
At very high altitudes, the IAS is low enough that zero flap is probably better. Also when flying very heavy, the altitude where the performance crosses over will be lower.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 11-26-2020, 12:45 AM
pierre smith's Avatar
Default Thanks...
Thanks, Steve, for the clear explanation of the ‘reflex’ system. I’ve had my -10 for ten years and never run at zero degrees. Heavily loaded, on the way to the Bahamas, 4 aboard, baggage and full fuel, we still got 190 MPH, Plus, at 7500”.
Regards,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 11-26-2020, 05:32 AM
Default confused
Sorry. I did not mean to cause some confusion. I said this:
"With 150 hrs in my RV10, I still don't understand the flaps.
What good is the -3 position?????"
based on this:
BobTurner "... slightly faster cruise at flaps zero."
rdrcrmatt "... I get airborne earlier with flaps 0°. Also, noticed even at low DA I lose 1-2 kts when I go flaps -3°"
I have not done any flt testing to to verify any of this. While my plane is very well built, the POH is somewhat lacking in performance data. It is on my lilst.
Dewey Clawson
Super Sabre Society
